USB3 performance tests
Rock64 2GB, Debian Jessie Minimal 0.5.15 arm64. Using a Seagate Expansion Desk 3TB formatted NTFS, connected to USB 3.0 port:
root@rock64:/srv/dev-disk-by-label-Data# iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
       Iozone: Performance Test of File I/O
               Version $Revision: 3.429 $
               Compiled for 64 bit mode.
               Build: linux
       Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins
                    Al Slater, Scott Rhine, Mike Wisner, Ken Goss
                    Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR,
                    Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner,
                    Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone,
                    Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root,
                    Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer,
                    Vangel Bojaxhi, Ben England, Vikentsi Lapa.
       Run began: Fri Feb  9 12:00:51 2018
       Include fsync in write timing
       O_DIRECT feature enabled
       Auto Mode
       File size set to 102400 kB
       Record Size 4 kB
       Record Size 16 kB
       Record Size 512 kB
       Record Size 1024 kB
       Record Size 16384 kB
       Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
       Output is in kBytes/sec
       Time Resolution = 0.000001 seconds.
       Processor cache size set to 1024 kBytes.
       Processor cache line size set to 32 bytes.
       File stride size set to 17 * record size.
                                                             random    random     bkwd    record    stride
             kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread
         102400       4     5986     9137    82147    83177    82198     9132
         102400      16    11101    11574   220777   244493   241593    11529
         102400     512    12439    12568   295507   327990   326474    12584
         102400    1024    12415    12467   297355   326899   327032    12564
         102400   16384    12368    12575   292642   326819   319953    12548
iozone test complete.
Rock64 4GB
Linux rock64 4.4.77-rockchip-ayufan-136 #1 SMP Thu Oct 12 09:14:48 UTC 2017 aarch64 GNU/Linux
Segate Expansion 2TB NTFS
rock64@rock64:~$ sudo iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
               Build: linux
       Run began: Thu Feb 15 20:39:40 2018
       Auto Mode
       Record Size 4 kB
       Record Size 16 kB
       Record Size 512 kB
       Record Size 1024 kB
         102400       4    17505    21424    22621    22694    18286    18333
         102400      16    32330    40698    61614    62298    49875    38584
         102400     512    72550    75073   122975   124031   119613    69184
         102400    1024    75479    75781   125448   126005   122854    69489
         102400   16384    76053    75591   128349   128305   128721    73892
Rock64 4GB
jessie-openmediavault
WD Blue 1TB (WD10JPVX)
        Build: linux
    Run began: Sat Mar 17 15:01:21 2018
    Auto Mode
    Record Size 4 kB
    Record Size 16 kB
    Record Size 512 kB
    Record Size 1024 kB
         102400       4    15649    20067    22398    21860      565     1368
         102400      16    57806    66567    73461    75961     2260     7752
         102400     512   114245   120221   124135   123221    43645    70388
         102400    1024   115715   115749   116693   125332    62990    83719
         102400   16384   111810   117813   102002   112283   112821   100822
WD 1TB + Seagate 2TB with mdadm configured in RAID 1 (using 1TB)
         102400       4    11064    14483    21416    21612     2096     1478
         102400      16    36284    45673    65649    61733     7517     6069
         102400     512   101186    88791   100516   105472    50369    68839
         102400    1024   102533   107210    96902    88704    61727    78498
         102400   16384   101480    92749    86578   104959   103556    75963
SSD 240 GB x2 with mdadm configured in RAID 1
         102400       4    13020    18288    28258    30029    15895    16820
         102400      16    46537    39254    99925    92208    49156    29525
         102400     512    54073   151005   281343   287526   256861   156370
         102400    1024   156593   121862   294304   299708   277053   163987
         102400   16384   171583   174020   320487   326101   304250   172703
  USB3.0 Issues at DietPi(Armbian) #22.02.1 t4_4t 3 2,338 08-15-2022, 06:58 PM
Last Post: TRS-80
  Forcing u-boot to detect USB3 storage jandastroy 8 11,300 04-02-2019, 10:06 PM
Last Post: t4_4t
Rainbow USB3 Detection Issues When Booting Without USB Device Attached Dargmuesli 0 1,970 01-14-2019, 11:26 AM
Last Post: Dargmuesli
  USB3 problems scalextrix 2 4,029 09-08-2018, 01:15 AM
Last Post: scalextrix
  Rock64 USB3 bugs NitroDeath 4 7,899 09-02-2018, 03:00 AM
Last Post: NitroDeath
  Arch Linux USB3 Issues? decontainerized 4 7,653 07-25-2018, 04:39 AM
Last Post: cooker
  Flaky USB3 on Bionic ayufan image hackish 7 7,623 06-15-2018, 08:32 AM
Last Post: fire219
Sad Rock64 4GB poor USB3 HDD performance KernelPanic 7 14,675 04-11-2018, 02:20 AM
Last Post: KernelPanic
  Rock64 as a firewall - usb3 gigE adopters jl_678 2 4,625 02-19-2018, 03:16 PM
Last Post: spawnflagger
  Root FS on usb3 drive eloranta 7 7,206 12-18-2017, 10:43 PM
Last Post: eloranta
