Left vs Right USB socket on Pinebook 14"
Just wanted to comment that I noticed that a USB HDD plugged into the LEFT USB port won't power up properly (looks like it can't get enough current), but plugged into the RIGHT USB socket it behaves normally.
Is this intentional?
It's not a problem as you can use the right hand socket but it is an inconvenience if you are not aware of it.
AK
Not sure but I noticed that if I use the left USB to try to charge a device, at least in Android, it crashes repeatedly, presumably because the power out is screwing with the power supply/controller. haven't tried the right USB for that, only for a mouse.
it doesn't get happy
it doesn't get sad
it just runs programs
Keep in mind that all the ports are limited to 500mA as per the USB spec. So running any harddrives or other things that need more than 500mA is more a game of luck and probably causes instability issues...
The left socket is a USB-OTG port, and not a 'normal' USB host port. That's why it behaves strangely.
The right port is a full USB root port.
  pinebook 1080p power/barrel connector/cable cel 0 535 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,364 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,213 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,615 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,293 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,591 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,589 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,726 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  Pinebook doesn't charge anymore Reinoud 0 2,667 08-20-2020, 08:18 AM
Last Post: Reinoud
Information How To Setup Serial Console Cable Over the Pinebook MarkHaysHarris777 4 22,853 07-02-2020, 06:33 PM
