java crashes
There has also been an issue with one of the images that was released, the 0.5.2 sd2emmc image, which has some broken packages by default. And noticeably to anyone needing java, that was one the packages that was broken.
if you reinstall the java package (openjdk8-headless-jre or something similar), it will fix that issue, but you may still have some broken packages. On the last few 0.7.x images there is a new script called pine64-diagnostics.sh which you can run, which has package verification (-v) and fix (-f) modes. You can always grab the latest version of it from my repo here.
