HDMI-VGA adapter. Blank screen.
(03-04-2017, 08:24 PM)Doryan Wrote: Does the LCD display struggle with this issue as well? I ask because I don't have money right now for a new monitor, but I could afford the display with the playbox enclosure.
So like many Pine 64 noobs out there, I can't seem to make my Pine64 work, probably the only gadget I've ever bought that I can't even get successfully troubleshoot, so anyway, is there a particular Linux OS image, preferably Ubuntu, that can run with a VGA to HDMI adapter?
No, the LCD display will work just fine, as it is designed to work with the pine64. Android builds work out of the box, and I believe Linux has been cracked (I haven't followed the LCD stuff of late, so will let Marcus or someone else comment further on that).
Pretty much any modern LCD / TV (i.e. made in the last 10 years) should work... but there is the occasional stubborn combo. As another data point, my BenQ E2420HD (24") display works fine with the Pine64 via HDMI, and was released in 2009. I also have a el-cheapo powered HDMI to VGA adapter which I have a old Dell LCD (4x3!!) monitor connected to (normally used with a Raspberry Pi), which also works fine with the pine64, although the display is squashed.
If you use the Armbian Ubuntu or Debian distros... you will be able to connect to the pine64 over your network (if connected by ethernet) out of the box via SSH, and can then configure WiFi if you need to. Otherwise, as Marcus pointed out, you'll want a USB to Serial adapter so you can check what is going on... maybe your pine64 is having problems booting, and the display isn't the issue at all? Or maybe it simply doesn't like the signals that adapter is providing... the pine64 does have a limited resolution set, so if the converter is requesting something different, it just won't work.
  USB adapter to eMMC module not recognized danril 0 1,315 11-25-2022, 04:16 AM
Last Post: danril
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 3,446 06-17-2021, 05:35 AM
Last Post: kqlnut
  7" LCD Touch Screen Panel IanJames 0 2,066 04-01-2020, 04:40 PM
Last Post: IanJames
  USB C hub and Ethernet adapter jaysistar 3 6,233 01-20-2020, 04:07 PM
Last Post: belfastraven
  Pine HDMI -> DVI monitor Pineapple 4 7,796 09-10-2019, 11:28 AM
Last Post: Pineapple
  User Screen Black After Changing Power Settings 0b51Gekko 2 4,743 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  First Boot HDMI/USB problem reefer 1 5,006 11-18-2018, 10:32 PM
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 8,178 04-15-2018, 07:37 AM
Last Post: bunkerWHz
  eMMC card on adapter Malmgren 8 11,225 03-20-2018, 11:14 AM
Last Post: Malmgren
  Rock64 + 7" touch screen naviathan 2 5,029 09-28-2017, 09:01 AM
Last Post: naviathan
