EULER bus question...
(05-22-2017, 04:06 PM)martinayotte Wrote: According to the DTS mentioned above by @pfeerick, it shows "clock-frequency" at 100MHz.
Personally, I've never use SPI at such speed, I usually use 10MHz or 25MHz.
And its good to point out at this juncture in the discussion, that if you're going to use speeds at or above 25 Mhz,  you're going to run into problems with plugable breadboards!  At such frequencies the 32pf capacitance of interconnections on the breadboard become shorts at that frequency.  Usually your project will require soldered breadboards with plenty of caps sprinkled around for decoupling.  I usually use SPI much slower ( slower than 10Mhz. )
  I2S Codec on Euler bus of Pine A64+ RANJITT76 8 10,338 01-17-2019, 02:25 AM
Last Post: ramstadt
  Supply DC power to Pine64 via Pi-2 Connector & Euler Bus? crapped 2 5,696 05-24-2018, 01:58 AM
Last Post: crapped
  Backer 12,931 - Shipping Question pspina3rd 13 15,158 07-30-2016, 07:10 PM
  Simple Question, has anyone successfully booted a 2Gb Pine? rahlquist 24 32,235 07-12-2016, 11:31 PM
  Backer 11,978; Shipping question GJurriens 3 4,726 07-12-2016, 06:55 PM
  Case question Fosterocalypse 5 5,707 05-02-2016, 10:35 PM
Last Post: Fosterocalypse
  Playbox Kit Question! TGCOM 8 10,980 02-22-2016, 12:13 AM
Last Post: Ghost
