Speaker at Euler Bus
I connected a little 8Ohm Speaker between Pin 31 and 32 on Euler bus but there is no sound at all. Is there enough power on these output to drive a speaker or do i need a amplifier? Is it right connected this way?? Is there a sound output at all on android on these pins???
You will want some sort of amp. I connected a small speaker the same way at one point, and it did work but it was very very quiet.
Also if you're using linux make sure you turn up the speaker volume in your mixer - it's separate from the headphone or hdmi volume.
Oops, just realized this is in the Android section. I don't know if that speaker output is enabled in Android, I've only used it in Linux.
I know in Android, if you plug something into the headphone jack it automatically switches the output to that jack. I'm not sure what you'd have to do to tell it to switch to the speaker out.
  USB Mic + HDMI Speaker jack_shepherd 0 1,877 11-27-2017, 03:27 AM
Last Post: jack_shepherd
  Worked first time, but anoying speaker clicks ecotack 11 13,086 05-02-2016, 05:48 PM
Last Post: Luke
