Microphone / Audio In
Has anyone had luck with audio input using the 3.5mm jack?
The audio out works fine, but I'm unable to record any sound.
I've tested using the old android 5 and the newer Android 6.0.1 (32 gb image, lcd/hdmi)
The camera, audio out, lcd / hdmi all work.
On mine, I had to fiddle a bit with the 3.5mm jack. After a few twists, I found a position in which the microphone also worked.
By the way, did you test the Pine camera or an USB camera?
(04-23-2017, 03:11 AM)kenjiru Wrote: On mine, I had to fiddle a bit with the 3.5mm jack. After a few twists, I found a position in which the microphone also worked.
I'll have to see if that somehow works.  I've tried with a few diff mics and none seemed to work.
I have had success with the Pine camera.  I haven't tried plugging in a USB camera though.  I was hoping to create a temporary makeshift baby monitor with a skype account, the pine camera and a mic.
By fiddling with the jack.. do you mean you just put the mic in, and wiggled it around for a while until it worked?
one thing to check is that you are using the proper plug for the audio socket on the pine64. information on the differing layouts of plug/socket is offered on this page.
https://en.wikipedia.org/wiki/Phone_conn...uter_sound
(04-23-2017, 07:09 AM)iammackinnon Wrote: By fiddling with the jack.. do you mean you just put the mic in, and wiggled it around for a while until it worked?
Yes, this is exactly what I did. Not sure what's the proper plug for Pine64, I just used a Samsung phone headphones. Make sure to insert the jack all the way in.
I've noticed that after reboot you have to unplug the microphone and plug it back in.
I forgot to mention that this was working on android-ver5.1.1-20161208-pine64-32GB.img.gz
  3,5mm audio out not working MikkoL 9 14,118 11-22-2020, 06:42 AM
Last Post: Little_Johnny
  Android audio Danbrack 0 2,182 03-24-2018, 10:51 PM
Last Post: Danbrack
  Microphone for Ok Google actions moondark 11 14,749 02-15-2018, 11:08 PM
Last Post: xnadoo
  <•••> and no audio on my android is Help PoppaLeague 0 1,924 09-10-2017, 01:32 AM
Last Post: PoppaLeague
  Android 6.0 TV analog audio Ophir 2 4,636 02-02-2017, 03:55 PM
Last Post: Ophir
Information Audio Passthrough in SPMC Working czechr08 8 17,742 11-02-2016, 06:54 PM
Last Post: czechr08
  USB Audio? mesaxi 3 4,538 09-28-2016, 09:45 PM
Last Post: mikey0000
  USB audio g_t_j 9 11,010 08-21-2016, 10:20 AM
Last Post: lifeke
  Passthrough Audio Netflix and Plex Android User 4127 10 13,265 07-26-2016, 12:01 PM
Last Post: CaptainZalo
  Audio from Headphone Jack and Camera Issue cybernak 1 3,301 05-23-2016, 11:02 AM
