Accelerated H.264 and HEVC video decoding with Cedrus
#41
Raspbit do you have longsleeps pine repos in your apt sources?
cat /etc/apt/sources.lst
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
#42
(05-10-2016, 10:32 PM)lenny.raposo-pine64.pro Wrote: Raspbit do you have longsleeps pine repos in your apt sources?
"File does not exist"
I just added this one to install sunxi-tool:
sudo apt-add-repository ppa:longsleep/ubuntu-pine64-flavour-makers
sudo apt-get update && sudo apt-get install sunxi-disp-tool
#43
ok here is the list of the packages available
https://launchpad.net/~longsleep/+archiv...our-makers
now simple do a sudo apt-get install package_name
Wink
Cheers Big Grin
#44
(05-11-2016, 02:03 AM)lenny.raposo-pine64.pro Wrote: ok here is the list of the packages available
Wrong (as usual) since package names there do not match necessarily. When do you start reading through the threads you post to? When do you start providing correct information? When do you start adding correct information to the blank pages at pine64.pro you call a FAQ? When do you stop recommending useless/counterproductive workarounds?
#45
you should try to be nice for once... i'm sure you can like this.
why the aggressive tone in almost every post ? Sad
#46
I'd like to get a better graphics performance but I have no idea how, could you guide me through the process?
#47
sudo -i
apt-get install xserver-xorg-video-fbturbo libump libcedrus1 libvdpau-sunxi1 sunxi-disp-tool
Cheers Big Grin
#48
(05-13-2016, 12:18 PM)lenny.raposo-pine64.pro Wrote: sudo -i
OK I have all this installed however I don't see anything like fbturbo using the mail module after install reboot and following instructions?
ubuntu@localhost:~$ lsmod
Module                                 Size  Used by
vfe_v4l2                          744450  0
mali                                190891  0
videobuf2_dma_contig         8772  1 vfe_v4l2
videobuf2_memops              1730  1 videobuf2_dma_contig
vfe_io                               30197  1 vfe_v4l2
cedar_ve                          13200  0
videobuf2_core                 24000  1 vfe_v4l2
ss                                    31983  0
8723bs                         1343876  0
cfg80211                        356431  1 8723bs
ppdev                                6388  0
parport                            18857  1 ppdev
What else do we need to get the fbturbo xserver accelerate?
Why do you think lsmod is a valid tool to check if fbturbo does use mali - it is not. Fbturbo does not use mali as of now (no working mali_drm module available in BSP) - check your xorg log to see the reasons and for accelleration details. Also, if you have installed my package from my PPA then you probably still need an xorg configuration. Its all described in the fbturbo docs - or if you are not interested in the details just use: https://github.com/longsleep/build-pine6...sh#L24-L32
#50
[quote pid='3468' dateline='1457810839']
Pine64 SoC temperature is stable at around 70C while decoding HEVC 1080p (without a heat sink, no enclosure).
For easy mplayer launches with the correct parameters feel free to use https://github.com/longsleep/build-pine6...er-play.sh
I will not support this overly much, but it confirms that the BSP Kernel has everything which is needed to use the media decoder in the Pine64.
Cheers
Simon
[/quote]
To be more precise: tested with calibrated instrument: 75degC.
Looks like heat sink will be needed anyway Smile
  Video wall? monty1 2 4,742 04-12-2017, 04:34 PM
Last Post: monty1
  pine64 accelerated jpeg decoding jacklau 1 4,081 01-12-2017, 01:12 AM
Last Post: Trizna
  Pine64 accelerated H.264 encoding hngjms 7 12,277 10-18-2016, 03:15 AM
Last Post: pfeerick
  The sunxi transform module is very slow, how to do video rotation? jacklau 0 2,398 09-19-2016, 12:24 AM
Last Post: jacklau
  Video encoding h.265/HEVC tomaThoma 1 6,081 07-02-2016, 11:35 PM
  Question about video acceleration BringItOn 10 15,274 06-23-2016, 10:33 AM
Last Post: ssvb
  Linux accelerated graphics nomadewolf 1 4,428 12-29-2015, 11:26 PM
