Volumio for PINE64 Released
New Volumio image is now available (many thanks Ge!)
(01-18-2019, 04:40 PM)Luke Wrote: New Volumio image is now available (many thanks Ge!)
(I get a 404 for the above link but I did eventually find it over at the volumio site.)
I'm a newbie to the forum here and semi-newbie to the Pine64. I got the 2GB board via kickstarter but only recently have I had time to actually use it. My first use was with Q4OS and it worked well. My next project is to build a stand-alone MP3 player for office use using Volumio & LCD (no network) to drive a set of headphones. I already have Volumio on a Pi w/LCD and DAC running and it works great but the price point looks like it's double that of the Pine64 solution.
My goal is to use the Pine64 with its LCD panel. If the headphone output is good enough, I'd prefer not to use a DAC in order to fit everything neatly in the LCD case sold by Pine64 which seems too short to handle add-on boards. Otherwise, I'll get the DAC and have an external headphone amp I can use; packaged into a custom case.
I've tried the last 3 releases of Volumio - the latest being the 1/12/19 release. I've come across three problems and am hoping someone has some feedback:
-1- I can only see the Volumio UI over the network. The board's HDMI output (which works fine with Q4OS) has no output with Volumio. I still need to buy the LCD panel so I can't test that yet. Has anyone gotten HDMI to work with Volumio? Has anyone gotten the LCD panel to work with Volumio?
-2- the volume control for the headphone output doesn't work from the Volumio controls. I get a fixed output level only. This is with "hardware" as the setting for volume control. In software mode, it does work but the noise level is really bad. Do I need to tweak some setting to make this work or should it work out of the box?
A fixed level output isn't a deal-breaker as I can use an external headphone amp that has its own volume control, except for problem 3.
-3- At the fixed volume, the headphone output has a noticeable level of background hiss. This doesn't seem to be related to the playback media. Is this just the way it's made or is this some Volumio artifact? I'm assume the plug-in DAC will solve this problem but I'd prefer to use keep the package small and neat.
Any hints or experience with Volumio on the Pine64 would be greatly appreciated.
tkx
-lou
  Programming languages support under PINE64 baryluk 6 12,290 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 9,221 03-28-2020, 06:20 PM
Last Post: ty1911
  Manjaro arm on pine64+ roel 2 5,900 10-19-2019, 05:13 AM
Last Post: roel
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 4,034 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 5,962 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 35,148 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 3,107 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 8,586 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 3,633 12-09-2017, 08:14 AM
Last Post: incoherent
  Fedora Running On Pine64! cztian 26 37,120 10-26-2017, 05:51 PM
Last Post: gregjo
