If I am wrong please correct my content , thank !
1. Use Pine64 Running Ubuntu 16.04 Web Server ( LAMP )
2. Use Pine64 Running Official Android 6 for Media player
3. Use Pine64 Running Volumio Digital Audio Player
Anyone know can play how long the LITHIUM BATTERY CASING?
1. Use Pine64 Running Ubuntu 16.04 Web Server ( LAMP ) 2. Use Pine64 Running Official Android 6 for Media player 3. Use Pine64 Running Volumio Digital Audio Player
03-05-2017, 05:41 PM
(03-05-2017, 06:35 AM)joe Wrote: any know it can play how long ? It's intended to accept 18650 lithium-ion cylindrical batteries/cell, and since it's based on a power bank case, I'd estimate that it is approximately 10cm long, 8cm wide, and 2cm high (give or take a few millimetres on each axis, and when on its side, as shown in the pictures). This is based on an aluminium 3-cell powerbank that I have that looks very similar in appearance, and also contains three batteries.
03-06-2017, 06:19 AM
Think Joe was asking about how long the Pine64 can run off the battery and not the physical size ? (I may be mistaken).
If yes, then granted you use 1500mha batteries (4500mha total) - I'd guess 3-4 hrs (depending on OS, application and load). (03-06-2017, 06:19 AM)Luke Wrote: Think Joe was asking about how long the Pine64 can run off the battery and not the physical size ? (I may be mistaken). You're Right , my bad English but thank pfeerick and luke ! If I am wrong please correct my content , thank !
Modern 18650 cells like the Panasonic NCR18650B 3,6V - 3,7V 3400mAh will give you around 10Ah in the battery pack which is about the same as the Pinebook battery...
Come have a chat in the Pine IRC channel >>
Battery and the PlayBox | JoeHz | 6 | 8,539 |
09-13-2016, 12:18 AM Last Post: gperez1234 |
Battery backup and automatic shutdown and startup | caseih | 9 | 10,923 |
05-09-2016, 10:17 AM Last Post: rahlquist |
