03-07-2016, 12:49 AM
Thats useful thanks! Is take4 with the updated u-boot/dt? Also your heat sink is very small. It would be interesting if a bigger one could get it to stay below cooling state 3 with this benchmark.
Pine 64 benchmarks
03-07-2016, 07:54 AM
Still with the old u-boot/dt. Heatsink is tiny (still better than nothing). I will test new dtb later today.
cheers
03-07-2016, 11:30 AM
(03-06-2016, 11:16 AM)janjwerner Wrote: Michael @ phoronix.com just benchmarked several ARM boards. http://www.phoronix.com/scan.php?page=ar...berry-pi-3 Not worth a look, he uses wrong numbers as usual: http://forum.armbian.com/index.php/topic...ple-times/ (03-06-2016, 08:04 PM)janjwerner Wrote: http://imgur.com/LyEl9dz Ahem, the most important information is missing: How low has the clockspeed been reduced? Cooler state 2-3 and reaching 90°C... I would suspect heavy throttling happened. Using a small fan and '-march=armv8-a -mtune=cortex-a53' it would be interesting how results improve. But unless you also improve heat dissipation it's rather useless to optimise compiler settings.
03-07-2016, 12:43 PM
(03-07-2016, 11:30 AM)Andrew2 Wrote:(03-06-2016, 08:04 PM)janjwerner Wrote: http://imgur.com/LyEl9dz Oh why didn't i see this yesterday .. @janwerner can you post the image with the CPU speed again please. Would also be interesting to see the difference when you updated the device tree. Thanks!
03-07-2016, 12:59 PM
(03-07-2016, 12:43 PM)longsleep Wrote: @janwerner can you post the image with the CPU speed again please. Would also be interesting to see the difference when you updated the device tree. Yes, this would really be interesting. But regarding 'raw performance' I made the experience that it's not worth a try to check the Pine64's real performance potential without a fan (I crashed mine yesterday, collision between fan and heatsink so I'll have to wait for a new one) BTW: Do you provide a new Xenial image soon or better upgrade the old one?
03-07-2016, 01:34 PM
constants reminders of my sloppiness. updated the orignal post. sorry guys...
03-07-2016, 01:40 PM
03-07-2016, 02:03 PM
(03-07-2016, 01:34 PM)janjwerner Wrote: constants reminders of my sloppiness. updated the orignal post. sorry guys... Thx, cpufreq not exceeding 1008MHz through the whole test and most of the times even lower (816 MHz minimum). With your current cooling capabilities the A64 can be considered to be clocked with approx. 950MHz. By adding a fan you can improve your benchmark scores by factor 1.2 (when thinking about 1152 MHz max). If @tllim adopts our ideas regarding power through Euler connector, a perfect heatsink and a fan solution that doesn't suck after an extensive set of tests the Pine64 might also be overclocked up to 1200 MHz, 1248, 1296 or even 1344 MHz (most probably not without tweaking the dvfs settings, increasing VDD_CPUX voltage and therefore massively the need for heat dissipation) benchmark results will improve by factor 1.25 or even 1.4 (at 1344 MHz). (using appropriate compiler switches and code optimizations might even work better )
03-08-2016, 12:07 AM
(This post was last modified: 03-08-2016, 12:12 AM by janjwerner.)
OK,
some more, this time according to the new article from Micheal: http://www.phoronix.com/scan.php?page=ar...i3-odroid2 phoronix-test-suite batch-benchmark 1603051-GA-ODROIDPI362 RPI-Monitor output: http://imgur.com/8uIJr87 cpu frequency counters: http://pastebin.com/aTEEa8P4 results: http://openbenchmarking.org/result/16030...603051GA88 memory card used: Samsung EVO class 10 32gb This test was ran on @longsleep's 2016_03_06 xenial If you want to run this tests make sure to create swap partition / enable swap file as FFMPEG will not build with 1GB of ram. next round with: export CXXFLAGS="-march=armv8-a -mtune=cortex-a53" export CFLAGS="-march=armv8-a -mtune=cortex-a53" |
Pine A64+ mainline mipi-dsi | Learnincurve | 3 | 6,432 |
01-12-2021, 07:36 AM Last Post: Learnincurve |
DietPi OS for PINE A64 | MichaIng | 0 | 9,042 |
12-15-2020, 06:11 AM Last Post: MichaIng |
Fedora 32/CentOS 8 Pine A64+ Images | wideawake | 2 | 5,357 |
10-02-2020, 11:38 AM Last Post: mathiraj |
LibreELEC(KODI) for Pine A64 (+) | pineadmin | 6 | 15,401 |
05-02-2020, 10:29 AM Last Post: aaronmarsh632 |
Lakka-nightlies for Pine A64 (and H64) | roel | 11 | 18,841 |
04-23-2020, 12:55 AM Last Post: roel |
Read DHT22 on Pine A64 | ayufan | 3 | 6,439 |
01-19-2020, 02:51 PM Last Post: {-DesT-} |
Centos 7 for Pine A64 | Luke | 2 | 5,948 |
05-28-2019, 12:18 AM Last Post: pineadmin |
NEMS Linux for Pine A64 (+) | Luke | 1 | 5,019 |
05-09-2019, 05:42 PM Last Post: pineadmin |
Pine Board using linux stuck during boot sequence | ktaragorn | 4 | 8,043 |
03-30-2019, 06:48 AM Last Post: ktaragorn |
motionEyeOS (PINE A64(+)) | pineadmin | 4 | 11,747 |
11-09-2018, 03:25 AM Last Post: pineadmin |
