camera array possible?
True! but, there are people who use pi camera which is also 5px and get well enough 3d model. See http://www.pi3dscan.com for example. I am thinking to follow the same method using pine64 to reduce some cost.
Sent from my ONE A2003 using Tapatalk
(02-26-2016, 02:26 PM)haskellf Wrote: Is it possible to attach multiple cameras to a single pine64, as a camera controller?
If not, is it possible to connect multiple pine64 (each with a camera) synced together to simultaneously take a photo from each camera?
I am looking to created my own camera array for Photogrammerty. Photogrammetry is the process of taking multiple camera shots from different parallax angles which are then processed in a software package to create a 3D representation of the target. I.E. take multiple photographs of a person from different angles to created a 3D representation.
I want to setup an array of pine64 cameras in a spherical formation all pointing towards a center point actor. The cameras will shoot a single image simultaneously and stored to a central drive. I was thinking that controlling the cameras and writing the images via ethernet would be a solution but some wise words from more technical modders would be most welcomed.
http://www.tested.com/art/makers/460057-...grammetry/
http://www.artanim.ch/blog/2014/02/build...d-scanner/
I like what is being discussed here. I am considering realtime 3D area mapping for security applications. If possible, I would like to attempt some image processing, like object and facial recognition.
A spark is all that is needed to start a raging fire..
  Pine64 as Security Camera / Baby Monitor utdrmac 2 7,132 02-01-2018, 07:49 AM
Last Post: davidbrucs
