2 GB Addon
I noticed with the 2GB addon that it says 'light assembly required'. Does anyone know what this will entail? Will this mean soldering is required or just plug in and go?
I guess that it means that u have to insert the wifi module
Or maybe cuz all the boards r going to be shipped with a boot switch but don't worry u don't have to solder anything
Sent from my HUAWEI Y530 using Tapatalk
By. Zoidiano0!
Installed:
LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5
Java 8 arm by oracle
Netbeans 8.1
chromium (uses way toooo much Ram)
Pine64 Head Unit Project.!
(02-22-2016, 04:44 PM)Zoidiano0 Wrote: I guess that it means that u have to insert the wifi module
Thanks on the correct answer. Just a simple few second snap job, no special tools or soldering is required.
