adafruit ultimate gps hat
https://learn.adafruit.com/adafruit-ulti...spberry-pi
since the pine 64 uses the pi2 pinout, would this work with my pine64 2gb?
Im looking to make a cheap but reliable NTP server to provide accurate ime to other ntp servers on my network.
The UART should be no problem, but PPS support you have to do some work, check which pin is used here first. I think someone added PPS support to a Pine a while ago (use search). Basically you have to add the devicetree entry defining the PPS pin and add the PPS driver to your linux kernel.
(02-16-2017, 06:27 PM)xalius Wrote: The UART should be no problem, but PPS support you have to do some work, check which pin is used here first. I think someone added PPS support to a Pine a while ago (use search). Basically you have to add the devicetree entry defining the PPS pin and add the PPS driver to your linux kernel.
... check !!  in addition you may have to add a pull-up  or  pull-down  resistor to the hat.  be careful.
Thumbs Up
hehe finally this might be just to much. im gonna try with another gps module i got that supports pps also. Should work better
for some reason i cant link the image properly
https://drive.google.com/file/d/1Jjwp7nL...sp=sharing
this i got for under 5$ im sure i can link it to the pine64 successfully
  Adafruit 16x2 LCD doesn't turn on with Pine64 mypineme 13 16,329 08-27-2016, 02:41 AM
Last Post: mypineme
  Setting up UART2 for Adafruit GPS hat stephen fleming 1 3,454 05-13-2016, 03:20 PM
Last Post: peterz
