Defect Compoent need help
Dear All
I had problem with the pine64 I had bought recently.
Try to log in a ticket and sending email to both the sales and support.
Have not received any update and reply.  Huh
(02-13-2017, 09:34 PM)francishui_sg Wrote: Dear All
The support ticket is the best option;  please be patient , if you have not heard from them in a couple of days PM TLLim.
In the mean time, I would try to remove the micro usb connector ( be careful ) and clean the board the best you can.  Then, provide power to the board via the euler bus  pin(6 +5v)  pin(4  ground).
That is how we recommend you power the board anyway !  The board is probably ok;  worth a try.
