Stuck after getting connected to Internet
Hi all
I am having problems with my Pine64. I have followed all the steps, but once I connect the board to the internet, via the WiFI module or the ethernet cable, it stops working.
There is absolutely nothing I can do, the screen goes grey or black and that is all.
I can disconnect the cable and then try again and it will work, but as soon as I reconnect... gone.
Is there anything I can do?
I will appreciate any information you can give me Smile
(I'm trying the Android 6.0 IMG - I have a Pine 2GB board and I have tried other OS and the same happens)
Many thanks,
Could be a power supply issue? Do you have a properly rated (2A+), non-charger USB supply with a good cable?
(01-28-2017, 06:34 AM)xalius Wrote: Could be a power supply issue? Do you have a properly rated (2A+), non-charger USB supply with a good cable?
Thank you so much, something that simple... It is working now! Smile Smile Smile
No problem, glad that it was easy to fix :-)
  stuck to sleep mode pinecil v2 lilibit 3 912 12-11-2023, 04:18 PM
Last Post: lilibit
  Newbie unable to connect to internet Derek7 2 3,005 07-16-2021, 12:41 AM
Last Post: Derek7
  Laptop as a bridge for Rock64's internet connection dmitrymyadzelets 3 5,275 03-28-2018, 05:24 AM
Last Post: dmitrymyadzelets
  Internet Necessity? Rickyroller5 3 4,799 10-24-2016, 07:43 PM
Last Post: MonarchOfLight
  Screen stuck in Portrait mode. domant 3 5,222 06-29-2016, 04:17 PM
Last Post: jjmgryphon
  Can't get internet connection galbez 4 6,852 05-22-2016, 09:43 AM
Last Post: Luke
  Stuck on the boot screen... PainOfPine 8 14,903 04-28-2016, 10:50 AM
Last Post: xrez
