Questions about GPIO
(02-16-2016, 03:15 PM)limitlesscodes Wrote: Alright, so I kind of figured out pin assignment using the GPIO image on the wiki. I still would like to know what PC, PD, PH, etc. means and when to use them vs. others. Also I would like to know if there is any better way of exporting the pins through C rather than doing something like:
Code: //near beginning of file
system("echo 71 > /sys/class/gpio/export")
and
Code: //near end of file
system("echo 71 > /sys/class/gpio/unexport")
You can fopen the file and write the string "71" to it like your first post. That's essentially what the echo is doing.
(02-16-2016, 11:45 PM)patrickhwood Wrote: (02-16-2016, 03:15 PM)limitlesscodes Wrote: Alright, so I kind of figured out pin assignment using the GPIO image on the wiki. I still would like to know what PC, PD, PH, etc. means and when to use them vs. others. Also I would like to know if there is any better way of exporting the pins through C rather than doing something like:
and
You can fopen the file and write the string "71" to it like your first post. That's essentially what the echo is doing. You are right! I knew I was missing something :p thanks.
Possibly Related Threads… |
Thread |
Author |
Replies |
Views |
Last Post |
GPIO specifications in device tree |
ramstadt |
1 |
3,168 |
01-16-2019, 03:17 PM
Last Post: ramstadt
+PINEBOOK Q4OS Pinebook Questions |
StewB |
0 |
2,230 |
08-24-2017, 03:53 PM
Last Post: StewB
Low-Level-GPIO-Access |
Thoams131 |
2 |
4,173 |
01-11-2017, 02:54 PM
Last Post: Thoams131
PPS-GPIO |
Sebastian |
11 |
16,238 |
07-12-2016, 07:25 PM
C#.NET / Mono GPIO library? |
abutler77 |
0 |
2,952 |
06-12-2016, 10:34 PM
Last Post: abutler77
Lazarus and GPIO |
gbestwick |
0 |
2,167 |
05-22-2016, 08:51 PM
Last Post: gbestwick
GPIO javascript library. |
neeeds |
1 |
3,635 |
02-19-2016, 11:31 PM
Last Post: limitlesscodes
