Android 6.0 Tablet and TV (release candidate, maintained)
Hi.
I just installed version android-6.0-pine-a64-tv-v1.0.2-r21. My mouse isn't working. It is a Logitech mouse. I can move the cursor around. My scroll button moves things up and down. However when I try to select something by double clicking the left button nothing happens. I use a HDMI switch. I have tried it both through the HDMI switch and directly connected and get the same result.
Both the HDMI switch and the Logitech mouse work correctly on the Pine using Android versions jenkins-android-tv-5.1-pine-a64-14 and android-7.0-pine-a64-14.
Any ideas how to get my mouse working in version android-6.0-pine-a64-tv-v1.0.2-r21?
Thanks.
Does anyone have any ideas how I can solve this and get mine Pine running again?
what i would do is fall back to one of the 2 working builds until the issue can be resolved on the problem build. that would get you back up and running and give the people who maintain the build time to investigate the bug. you are talking about the pine build as the one with the issue right?
dkryder. Thanks for your help trying to get my Pine going again. It is frustrating to have my mouse working but not be able to click on anything to select it.
I tried what you suggested. I have 2 Pines and 3 SD cards. My problem is that when I installed the 6.0 r21 on my spare SD I then put the spare SD in the Pine with version 5.1 in it I immediately overwrote the working version of 5.1 thinking I would replace on my other Pine with version 7.0 with a more stable version (6.1).
Now whenever I try to download and install any of ver 5.1, 5.1 or 7.1 I get the same issue occurring. I can see my mouse move but can't click with the left button to select anything.
As a result I can't fall back to one of the working builds.
I am using Etcher to install the image if that helps diagnose the issue.
Bob, let it boot without the usb devices plugged in. then plug them in and determine which button on the mouse, left or right, works for selection. you may have it set for left hand mouse when you want right hand, or the other way around. then find in settings where the option of left or right hand mouse is and select option you want.
dkryder. It was worth a shot. I tried booting version 6.0 r21 having nothing plugged into the USB ports. I then plugged into the USB port. I got the same thing. I can move the mouse around but can't select anything using the right or left mouse buttons.
I am using a KVM switch for HDMI. The switch is working fine for video and worked fine using the old Android version.
well, if it is a known good mouse then i'm stumped.
The mouse works good with other PC's on the switch.
I should have added that one of the other PC's that the mouse works correctly with is a Pine with an old version of 7.0. The mouse only doesn't work with a new version I create be that 5.1, 6.0 or7.1.
Hi
I am using pine64 2gb with android-6.0-pine-a64-tv-v1.0.2-r21.I am getting video and sound through hdmi. Everything seems to work great. However, if I watch videos for a long time, the next time when I start watching the sound doesn't work. It starts working again if I unplugged everything and give it a rest for couple of days.
Has anybody experienced it? How can I fix this?
i cannot Use the last Update.
Is that because, there is no TV Version?
Kind regards
(04-10-2017, 02:04 PM)Bob123456789 Wrote: Hi.
Thanks.
You can just control the Pine with the Android TV Remote APK on your Mobile Device (Tablet)
It works for me Fine.
Kind regards
Shocked Remote for Android? liodra 18 29,587 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,756 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 6,967 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,036 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,598 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,334 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 257,059 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,542 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 104,866 02-10-2019, 07:44 PM
Last Post: mmmarcus
  +LTS/SOPINE Android SDK support and Customization biplab777 1 4,668 01-07-2019, 01:21 AM
