bluetooth low energy
I try to emulate a Beacon balise with the Pine64 (I currently use Android 5.1), but that seem to doesn't work.
Does someone has successfully use the Pine64 to emulate a beacon on Android or Another system?
Regards
Dworkin
(11-22-2016, 05:19 AM)dworkin Wrote: Hello,
Regards
Dworkin
Are you referring to the Beacon balise used on the French rail system ?
... if so are you trying to "read" the balise , or are you trying to emulate the on-board computer that "reads" and processes the balise ?
Perhaps you're trying to model the warning system on a model railroad ?
  Wifi/Bluetooth module riahim 7 8,917 07-05-2016, 10:19 PM
Last Post: Ghost
  Bluetooth Keyboard - Mouse Ron Piggott 3 6,986 12-25-2015, 09:24 PM
