Raspberry Pi projects on Pine64
I bought the pine a64 on Kickstarter and i would like if projects made for the Raspberry Pi will be compatible with the pine ?
Thank you !
Cookeys
(02-11-2016, 10:31 AM)cookeys Wrote: Hi,
Thank you !
Cookeys
Hi there!
You may need to be more precise with what you mean by 'projects'. The Pine and the Pi use slightly different ARM processors, though the GPIO pinout of the Pi and the Pine's pi-2 interface are the same. So likely, modifications will need to be made to projects in order to get them to work.
[/quote]
Hi there!
[/quote]
Thank You for your answer ;
I have no project in particular tu realize and I start IoT with Pine a64 but i just receive a newspaper about Raspberry and I'm thinking if projects will be compatible.
Thank You for your time
Cookeys
Question External storage problem for pine64 Dani6102 4 1,618 08-22-2023, 08:36 AM
Last Post: gulshan212
  Pine64 as wireless audio device S265 3 3,156 04-07-2022, 10:39 PM
Last Post: S265
  Pine64(+) and manjaro dsychan 0 1,109 04-05-2022, 11:32 PM
Last Post: dsychan
Thumbs Down Pine64 was a Useless Project pushpendrak 18 28,314 11-21-2020, 10:17 PM
  Pine64 LCD rstcologne 0 3,091 09-22-2020, 12:43 PM
Last Post: rstcologne
  Pine64+ power button PaddyChan 0 2,741 09-14-2020, 09:55 AM
Last Post: PaddyChan
  Pine64 OS dpcons 2 4,896 03-02-2020, 04:32 PM
Last Post: dpcons
  Jailhouse supports Pine64+ vj-kumar 0 2,803 02-17-2020, 11:39 PM
Last Post: vj-kumar
  PINE64 board not powering up loki21century 2 5,514 11-25-2019, 12:19 PM
Last Post: Partymack711
  Pine64 not powering up. skylab 5 7,161 05-03-2019, 02:48 PM
Last Post: Mendota
