installing resilio-sync package
Has anyone had luck installing
https://www.resilio.com/ previously Bittorrent Sync.
I got all turned around as the instructions are questionable...to the point I'm not even sure which version to attempt to install next.
https://help.getsync.com/hc/en-us/articl...e-on-Linux
I'm using Debian.
thanks
I need help with this too. Following the directions on their site for 64 bit ARM lets me install the package, but I can't run it.
EDIT: Tried to install it again, but trying to run it gave me some systemctl errors. I'm running armbian with a 4.2 kernel.
(11-15-2016, 12:25 PM)howardsternisbatman Wrote: Has anyone had luck installing
I'm using Debian.
thanks
Hi.
I really don't know about this one, but Syncthing runs ok and does not need any install.
Att.
  Help needed - installing Parrot OS on PINE A64+2GB Board Doryan 1 3,905 03-05-2018, 01:38 AM
Last Post: joe
