HDMI not working
I have a working install using the pine64 touch screen monitor.  I was thinking I might want to use the HDMI output as an occasional option. However if I disconnect the touchscreen I get no signal out on HDMI. It will send a signal with screen connected but only a partial screen. Been a while since I did the install and for personal reason had to shelf working on the project. Does the install only work with the touch screen? Would I need another install to functionally use the HDMI.
If ur r using Android
To have booth screens active led and hdmi u need to set in the uEnv file
Lcd on
If u want only hdmi u have to disable Lcd
If u r using Linux
There's no way to use booth at the same time at the moment
Sent from my Xperia V using Tapatalk
By. Zoidiano0!
Installed:
LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5
Java 8 arm by oracle
Netbeans 8.1
chromium (uses way toooo much Ram)
Pine64 Head Unit Project.!
OK is that something I can do within the OS on android? It would seem not. Where would that file be located and how does one edit with android? Sorry but new to android platform. Kinda why I got this thing.
Int he ayufan thread of android 7
There's some information about how to edit configurations
The uEnv.txt file is located in the boot partition of th sdcard
Is the portion that shows up when u plug the SD on your pc
U can edit that file
In the latest version 1.8
In the file itself there's the information u need to set your configuration
Just uncomment the line that u want to use or comment it to disable
U comment by adding
# in front of the line u want to use
And uncomment by deleting it
In the newer version of Android there's root acces to apps so u can use any file editor to mod the file form the system
Just go to the root folder of the system and then go to the boot directory
PDT:
If u want to. Use the hdmi and Lcd at the same time u need to start it without the hdmi cable
Attach it after boot
By. Zoidiano0!
Installed:
Netbeans 8.1
I can open several volumes on my linux laptop. Doing a search for uEnv.txt returns no results. Searching root file within Android OS also return no Boot directory and no uEnv.txt file
Please give full directory path to file such as /dev/boot/uEnv.txt
Using Android 5.1.1 LCD installed
There's no so much flexibility
On that version
Cuz I thought u were talking about the nougat version
Download that one there's more setting to play with and now we have root acces to apps as well
Check the Android 7 thread
By. Zoidiano0!
Installed:
Netbeans 8.1
Thanks I will probably wait until its a bit more stable.
Your question helped me.
Possibly Related Threads...
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 5 316 Yesterday, 08:31 AM
Last Post: rookieone
  HDMI Color Inverted on TV Apicalis 1 96 01-16-2017, 04:25 PM
  anyone make pine64 lcd hdmi work simultaneously bokeer 4 301 12-11-2016, 05:57 PM
Last Post: Luke
Information Audio Passthrough in SPMC Working czechr08 8 1,652 11-02-2016, 06:54 PM
Last Post: czechr08
  Netflix and Twitter no longer working Punkyclown 0 170 10-20-2016, 08:45 AM
Last Post: Punkyclown
  Supported 4:3 and 16:10 resolutions over HDMI on Android karlitos 21 3,069 10-11-2016, 08:20 AM
Last Post: Napalm
  3,5mm audio out not working MikkoL 5 226 09-29-2016, 03:24 PM
Last Post: jjmgryphon
  Touch not working with Android and touch screen erichardson30 5 483 09-13-2016, 11:12 AM
Last Post: MarkHaysHarris777
  HDMI CEC on Android fneves 38 5,008 09-06-2016, 04:07 AM
Last Post: hadi
  Build the Lichee and Android source-"Android 5.1.1 Image (HDMI Video Output) Release SuperX 2 372 08-12-2016, 02:00 AM
Last Post: xalius
