Reset system
Android Lollipop, HDMI mode. I was connected to a 720p tv. Playing with the settings and inadvertantly selected 1080p and lost the video signal. I have the reset button, and on/off switches, installed. Neither one reset the video signal. Any ideas? I could re-burn the chip but I'm hoping for an easier solution.
(10-16-2016, 02:50 PM)mcrognale Wrote: Android Lollipop, HDMI mode. I was connected to a 720p tv. Playing with the settings and inadvertantly selected 1080p and lost the video signal. I have the reset button, and on/off switches, installed. Neither one reset the video signal. Any ideas? I could re-burn the chip but I'm hoping for an easier solution.
Unfortunately the setting is persistent.
If you do not want to burn a new image ( which might just be the easiest way ) find a set ( even a friends set ) that supports 1080p60 and set it back to 720p60 ( that is relatively easy too ).
Thanks Mark. I can always depend on you for the right answer. Not an issue for me to re-burn it. I do this a lot for the ham radio apps that I use. Of course I could just buy a 1080 monitor since I sort of planned to do that anyway for the ham android apps.
  Just received Pinephone - system crashes Zebulon Walton 12 13,834 11-13-2020, 05:45 PM
  reset postmarket os to factory specifications jmak 2 4,413 10-02-2020, 08:30 PM
Last Post: SwordfishII
  No top system menu maxchess 3 5,009 06-14-2019, 07:11 AM
Last Post: maxchess
  qemu-system-aarch64 11b2p508 1 3,373 07-19-2018, 10:26 PM
Last Post: shizzle411
  Office System 24/7 donisonleague 2 3,840 07-04-2018, 06:22 PM
Last Post: donisonleague
  Robot Operating System (ROS) jesse1234 8 11,208 02-28-2017, 08:33 PM
Last Post: dkryder
  No Power or Reset buttons corymp 7 10,662 07-20-2016, 11:12 AM
Last Post: CaptainZalo
