android image & sd card size problems
(01-23-2017, 05:41 AM)npull Wrote:
(01-16-2017, 01:14 PM)projectrem Wrote: Hi - new to this- I was told that the LCD option requires android 5.1 scpecifically for the lCD resolution support.  Do you know if others have successfully used newer versions of android with the LCD?  Thanks for your time.
Ayufan's images for android 6 and 7 works just fine with the LCD touch screen aswell, you just have to enable it in uEnv.txt uncomment the pine64_lcd=on.
May I know how I can edit the uEnv.txt file (located in /bootloader) when I am using Ayufan's Android version 6 as recommended ? I have tried editing directly in the Android once booted up to no avail with permission issue. Do I have to download the source, edit specific file in source and compile the source into image file for burning into microSD card or there is better/easier way to do it on my iMac (macOS 10.11) ?
Thanks in advance.
Write image. And edit that from your iMac.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 388,218 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,647 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,815 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 6,984 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,051 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,614 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,340 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 257,826 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,548 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,162 02-10-2019, 07:44 PM
Last Post: mmmarcus
