Trimming Edges of LCD Panel
Stock LCD of Pine64 is way bigger for my project. Can we cut the edges of the touch panel with laser cnc?  What are the limitations?
Thanks.
http://files.pine64.org/doc/datasheet/pi...PG-V01.pdf
Here is the datasheet and drawing of the touch panel
I'm not an expert on this drawings but seems possible
Give it a look
Sent from my Xperia V using Tapatalk
By. Zoidiano0!
Installed:
LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5
Java 8 arm by oracle
Netbeans 8.1
chromium (uses way toooo much Ram)
Pine64 Head Unit Project.!
  LCD panel with RGB LEDs Ghost 3 4,337 02-09-2016, 02:27 AM
Last Post: RaspiBit
