Getting Temperature/Humidity/Ambient Light data with Python
I have tried to get data from both the Temp/Humidity and the Ambient Light sensor by using python and python-smbus. I have found and read the tech docs of both adapters as specified by Pine64 but have not gotten all the way to reading the correct data, i.e. I get data from the T/H sensor but it says that it's -5 C inside and I don't believe that since I'm sitting in short-sleeves...  Smile
I also found the posts from khgoh (http://forum.pine64.org/showthread.php?tid=231&page=3) and skimmed through the source code for the WifiRemoteI2C server but that is in C (C++) and does not help me at all, or rather, it does not help me solving it in python...
My problem is that the value I get from the T/H sensor does not convert correctly into the ambient temperature and relative humidity.
I would really appreciate if someone told me where I am going wrong and how to correct it.
Many thanks
DS
Source:
import smbus
import time
bus = smbus.SMBus(1)
address = 0x40
cmd_temp = 0xE3
cmd_humid = 0xE5
temp = 0L
humid = 0L
temp = bus.read_word_data(address, cmd_humid)
print "RH read_word_data returns ", humid
print ""
humid = 125.0 * humid / 65536 - 6
print "RH: ", humid, " %"
print ""
print ""
temp = bus.read_word_data(address, cmd_temp)
print "Temp read_word_data returns ", temp
print ""
temp = 175.72 * temp / 65536 - 46.85
print "Temperature: ", temp, " C"
print ""
print ""
Output:
debian@pine64:~/i2c$ python getTemp2.py
RH read_word_data returns  0
RH:  -6.0  %
Temp read_word_data returns  10341
Temperature:  -19.1229412842  C
The first step is to use the i2c toolset to see if you can see your device address. if your device is on the wrong i2c bus you won't see the address. The (TWI) bus is reserved. Once you know the address of the device , then you can worry about reading it.
Usually, to read an i2c device you first have to write to it;  this tells the device which register you want to read-- then you have to know whether the data is coming back to you little-endian or big-endian; and this can make a huge difference in terms of interpretation ( if you have the high and low orders confused the data is not going to make much sense ).
The data-sheet is going to be absolutely necessary.
Hi MarkHaysHarris777,
Thanks for your reply. I must have been unclear in my first post - I am getting data from the T/H sensor, therefore, I have the correct address and bus. Smile
I was actually thinking about litte-endian vs. big-endian as the cause of my problem since I can see that the T/H sensor sends the result MSB-LSB (can't remember which of the endians that is). So you suggest that I need to switch the order of the returned bytes and the do the conversion again?
When you say that I must first write to the I2C device and then read. Do you mean that the smbus command "read_word_data(addr,cmd)" does not write the code in cmd before reading? The only documentation I found is here. I tried writing the command first (using write_byte(0x40, 0xE5)) and then issuing "read_word_data(0x40, 0xE5)" but get similar results.
I am probably missing some essential part that is right under my nose... Sad
So I got an answer with code from DonH, thank you very much!   :thumbs_up:
In order to share the knowledge I am pasting the code he sent me. Essentially you need to tell the sensor to do a measurement and then read the result - which, ironically, is what I did to start with. Except that I only waited 0.02 seconds whereas this code waits 0.5 seconds...
Here's the code, originally from ControlEverything.com and modified for this purpose by DonH:
# Distributed with a free-will license.
# Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
# STS21
# This code is designed to work with the STS21_I2CS I2C Mini Module available from ControlEverything.com.
# https://www.controleverything.com/conten...t_tabset-2
import smbus
import time
# Get I2C bus
# STS21 address, 0x4A(74)
# Select Command
#        0xF3(243)    Temperature measurement in NO HOLD mode
bus.write_byte(0x40, 0xF3)
time.sleep(0.5)
# Read data back, 2 bytes, MSB first
data0 = bus.read_byte(0x40)
data1 = bus.read_byte(0x40)
# Convert the data
temp = (data0 * 256 + data1) & 0xFFFC
cTemp = -46.85 + (175.72 * temp / 65536.0)
fTemp = cTemp * 1.8 + 32
# Output data to screen
print ("Temperature in Celsius is :  %.2f C") %cTemp
print ("Temperature in Fahrenheit is :  %.2f F") %fTemp
bus.write_byte(0x40, 0xF5)
time.sleep(0.5)
data2 = bus.read_byte(0x40)
data3 = bus.read_byte(0x40)
humidity = (data2 * 256 + data3) & 0xFFFC
rHumidity = ((125*humidity)/65536)-6
print ("Relative humidity is :  %.2f ") %rHumidity
In order to complete this request I will now post the code I put together for measuring the Lux value from the Ambient Light Sensor.
This code is mostly from the manufacturer of the sensor that is used, or rather the sensor used is based on this one ("Base on TAOS/AMS TSL2561T I2C Light Sensor").
The original code was in C/C++ but I ported it to Python, please tell me if I made mistakes in porting the code, and the reading of the device registers is based on above code.
Have fun  Smile
Yomet
# -*- coding: utf-8 -*-
import smbus
import time
# The following code has been adapted from the manufacturers suggested code for converting
# the Ambient Light measures in Channel 0 and Channel 1 to a Lux value.
# Ch0 = visible & IR light
# Ch1 = IR light only
# Original code was in C and is available at :
# http://ams.com/eng/content/download/250094/975485/142937
# Copyright ams AG, Inc.
# THIS CODE AND INFORMATION IS PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE IMPLIED WARRANTIES OF MERCHANTABILITY AND/OR FITNESS FOR A
# PARTICULAR PURPOSE.
# Module Name: lux.cpp
#unsigned int CalculateLux(unsigned int iGain, unsigned int tInt, unsigned int ch0, unsigned int ch1, int iType)
def CalculateLux(iGain, tInt, ch0, ch1, iType):
   LUX_SCALE = 14 # scale by 2^14
   RATIO_SCALE = 9 # scale ratio by 2^9
   # Integration time scaling factors
   CH_SCALE = 10 # scale channel values by 2^10
   CHSCALE_TINT0 = 0x7517 # 322/11 * 2^CH_SCALE
   CHSCALE_TINT1 = 0x0fe7 # 322/81 * 2^CH_SCALE
   # T, FN, and CL Package coefficients
   # For Ch1/Ch0=0.00 to 0.50
   #    Lux/Ch0=0.0304-0.062*((Ch1/Ch0)^1.4)
   #    piecewise approximation
   #       For Ch1/Ch0=0.00 to 0.125:
   #          Lux/Ch0=0.0304-0.0272*(Ch1/Ch0)
   #       For Ch1/Ch0=0.125 to 0.250:
   #          Lux/Ch0=0.0325-0.0440*(Ch1/Ch0)
   #       For Ch1/Ch0=0.250 to 0.375:
   #          Lux/Ch0=0.0351-0.0544*(Ch1/Ch0)
   #       For Ch1/Ch0=0.375 to 0.50:
   #          Lux/Ch0=0.0381-0.0624*(Ch1/Ch0)
   # For Ch1/Ch0=0.50 to 0.61:
   #    Lux/Ch0=0.0224-0.031*(Ch1/Ch0)
   # For Ch1/Ch0=0.61 to 0.80:
   #    Lux/Ch0=0.0128-0.0153*(Ch1/Ch0)
   # For Ch1/Ch0=0.80 to 1.30:
   #    Lux/Ch0=0.00146-0.00112*(Ch1/Ch0)
   # For Ch1/Ch0>1.3:
   #    Lux/Ch0=0
   K1T = 0x0040 # 0.125 * 2^RATIO_SCALE
   B1T = 0x01f2 # 0.0304 * 2^LUX_SCALE
   M1T = 0x01be # 0.0272 * 2^LUX_SCALE
   K2T = 0x0080 # 0.250 * 2^RATIO_SCALE
   B2T = 0x0214 # 0.0325 * 2^LUX_SCALE
   M2T = 0x02d1 # 0.0440 * 2^LUX_SCALE
   K3T = 0x00c0 # 0.375 * 2^RATIO_SCALE
   B3T = 0x023f # 0.0351 * 2^LUX_SCALE
   M3T = 0x037b # 0.0544 * 2^LUX_SCALE
   K4T = 0x0100 # 0.50 * 2^RATIO_SCALE
   B4T = 0x0270 # 0.0381 * 2^LUX_SCALE
   M4T = 0x03fe # 0.0624 * 2^LUX_SCALE
   K5T = 0x0138 # 0.61 * 2^RATIO_SCALE
   B5T = 0x016f # 0.0224 * 2^LUX_SCALE
   M5T = 0x01fc # 0.0310 * 2^LUX_SCALE
   K6T = 0x019a # 0.80 * 2^RATIO_SCALE
   B6T = 0x00d2 # 0.0128 * 2^LUX_SCALE
   M6T = 0x00fb # 0.0153 * 2^LUX_SCALE
   K7T = 0x029a # 1.3 * 2^RATIO_SCALE
   B7T = 0x0018 # 0.00146 * 2^LUX_SCALE
   M7T = 0x0012 # 0.00112 * 2^LUX_SCALE
   K8T = 0x029a # 1.3 * 2^RATIO_SCALE
   B8T = 0x0000 # 0.000 * 2^LUX_SCALE
   M8T = 0x0000 # 0.000 * 2^LUX_SCALE
   # CS package coefficients
   # For 0 <= Ch1/Ch0 <= 0.52
   #    Lux/Ch0 = 0.0315-0.0593*((Ch1/Ch0)^1.4)
   #       For 0 <= Ch1/Ch0 <= 0.13
   #          Lux/Ch0 = 0.0315-0.0262*(Ch1/Ch0)
   #       For 0.13 <= Ch1/Ch0 <= 0.26
   #          Lux/Ch0 = 0.0337-0.0430*(Ch1/Ch0)
   #       For 0.26 <= Ch1/Ch0 <= 0.39
   #          Lux/Ch0 = 0.0363-0.0529*(Ch1/Ch0)
   #       For 0.39 <= Ch1/Ch0 <= 0.52
   #          Lux/Ch0 = 0.0392-0.0605*(Ch1/Ch0)
   # For 0.52 < Ch1/Ch0 <= 0.65
   #    Lux/Ch0 = 0.0229-0.0291*(Ch1/Ch0)
   # For 0.65 < Ch1/Ch0 <= 0.80
   #    Lux/Ch0 = 0.00157-0.00180*(Ch1/Ch0)
   # For 0.80 < Ch1/Ch0 <= 1.30
   #    Lux/Ch0 = 0.00338-0.00260*(Ch1/Ch0)
   # For Ch1/Ch0 > 1.30
   #    Lux = 0
   K1C = 0x0043 # 0.130 * 2^RATIO_SCALE
   B1C = 0x0204 # 0.0315 * 2^LUX_SCALE
   M1C = 0x01ad # 0.0262 * 2^LUX_SCALE
   K2C = 0x0085 # 0.260 * 2^RATIO_SCALE
   B2C = 0x0228 # 0.0337 * 2^LUX_SCALE
   M2C = 0x02c1 # 0.0430 * 2^LUX_SCALE
   K3C = 0x00c8 # 0.390 * 2^RATIO_SCALE
   B3C = 0x0253 # 0.0363 * 2^LUX_SCALE
   M3C = 0x0363 # 0.0529 * 2^LUX_SCALE
   K4C = 0x010a # 0.520 * 2^RATIO_SCALE
   B4C = 0x0282 # 0.0392 * 2^LUX_SCALE
   M4C = 0x03df # 0.0605 * 2^LUX_SCALE
   K5C = 0x014d # 0.65 * 2^RATIO_SCALE
   B5C = 0x0177 # 0.0229 * 2^LUX_SCALE
   M5C = 0x01dd # 0.0291 * 2^LUX_SCALE
   K6C = 0x019a # 0.80 * 2^RATIO_SCALE
   B6C = 0x0101 # 0.0157 * 2^LUX_SCALE
   M6C = 0x0127 # 0.0180 * 2^LUX_SCALE
   K7C = 0x029a # 1.3 * 2^RATIO_SCALE
   B7C = 0x0037 # 0.00338 * 2^LUX_SCALE
   M7C = 0x002b # 0.00260 * 2^LUX_SCALE
   K8C = 0x029a # 1.3 * 2^RATIO_SCALE
   B8C = 0x0000 # 0.000 * 2^LUX_SCALE
   M8C = 0x0000 # 0.000 * 2^LUX_SCALE
   # lux equation approximation without floating point calculations
   # Routine: unsigned int CalculateLux(unsigned int ch0, unsigned int ch0, int iType)
   # Description: Calculate the approximate illuminance (lux) given the raw
   #              channel values of the TSL2560. The equation if implemented
   #              as a piece-wise linear approximation.
   # Arguments: unsigned int iGain - gain, where 0:1X, 1:16X
   #            unsigned int tInt - integration time, where 0:13.7mS, 1:100mS, 2:402mS, 3:Manual
   #            unsigned int ch0 - raw channel value from channel 0 of TSL2560
   #            unsigned int ch1 - raw channel value from channel 1 of TSL2560
   #            unsigned int iType - package type (T or CS)
   # Return: unsigned int - the approximate illuminance (lux)
   # first, scale the channel values depending on the gain and integration time
   # 16X, 402mS is nominal.
   # scale if integration time is NOT 402 msec
   chScale = 0L
   channel1 = 0L
   channel0 = 0L
   if tInt == 0: # 13.7 msec
       chScale = CHSCALE_TINT0
   elif tInt == 1: # 101 msec
       chScale = CHSCALE_TINT1
   else: # assume no scaling
       chScale = (1 << CH_SCALE)
   # scale if gain is NOT 16X
   if iGain == 0:
       chScale = chScale << 4 # scale 1X to 16X
   # scale the channel values
   channel0 = (ch0 * chScale) >> CH_SCALE
   channel1 = (ch1 * chScale) >> CH_SCALE
   # find the ratio of the channel values (Channel1/Channel0)
   # protect against divide by zero
   ratio1 = 0L
   if channel0 != 0:
       ratio1 = (channel1 << (RATIO_SCALE+1)) / channel0
   # round the ratio value
   ratio = (ratio1 + 1) >> 1;
   b = 0
   m = 0
   if iType == 0: # T, FN and CL package
       if ((ratio >= 0) and (ratio <= K1T)):
           b = B1T
           m = M1T
       elif (ratio <= K2T):
           b = B2T
           m = M2T
       elif (ratio <= K3T):
           b = B3T
           m = M3T
       elif (ratio <= K4T):
           b = B4T
           m = M4T
       elif (ratio <= K5T):
           b = B5T
           m = M5T
       elif (ratio <= K6T):
           b = B6T
           m = M6T
       elif (ratio <= K7T):
           b = B7T
           m = M7T
       elif (ratio > K8T):
           b = B8T
           m = M8T
   elif iType == 1:# CS package
       if ((ratio >= 0) and (ratio <= K1C)):
           b = B1C
           m = M1C
       elif (ratio <= K2C):
           b = B2C
           m = M2C
       elif (ratio <= K3C):
           b = B3C
           m = M3C
       elif (ratio <= K4C):
           b = B4C
           m = M4C
       elif (ratio <= K5C):
           b = B5C
           m = M5C
       elif (ratio <= K6C):
           b = B6C
           m = M6C
       elif (ratio <= K7C):
           b = B7C
           m = M7C
       elif (ratio > K8C):
           b = B8C
           m = M8C
   temp = 0L
   temp = ((channel0 * b) - (channel1 * m))
   # do not allow negative lux value
   if temp < 0:
       temp = 0
   temp += (1 << (LUX_SCALE-1))
   # strip off fractional portion
   lux = 0L
   lux = temp >> LUX_SCALE
   return lux
address = 0x49
#Start the device, only needs to be done when the device is first booted
bus.write_byte_data(address, 0x80, 0x03)
time.sleep(0.5)
# Specs on the spec sheet page 30 (Basic Operation)
# TSL2560-61_DS000110_2-00.pdf
Ch0L = bus.read_byte_data(address, 0x8C)
Ch0H = bus.read_byte_data(address, 0x8D)
Ch0 = Ch0H * 256 + Ch0L
Ch1L = bus.read_byte_data(address, 0x8E)
Ch1H = bus.read_byte_data(address, 0x8F)
Ch1 = Ch1H * 256 + Ch1L
# If I understood the technical documents correctly, the Ambient Light Sensor that
# Pine64 uses should use the FN package calculations.
# http://ams.com/eng/Products/Light-Sensors/Ambient-Light-Sensors/TSL2561
# under Technical Documents / Using the Lux Equation
# http://ams.com/eng/content/view/download/145438
print "Calculation of Lux according to the T, FN and CL packages"
light = CalculateLux(0, 2, Ch0, Ch1, 0) # T, FN and CL package
print "Lux = ", light
#print "Calculation of Lux according to the CS package"
#light = CalculateLux(0, 2, Ch0, Ch1, 1) # CS package
#print "Lux = ", light
Congratulations !
Hi again.
I add new sensors test here: http://forum.pine64.org/showthread.php?t...6#pid20736
Now you can test library. Download from here: https://github.com/blademoon/Sensus
If you have comments or suggestions, please contact me.
(10-01-2016, 02:51 AM)MarkHaysHarris777 Wrote: Congratulations !
Thanks!  Smile
(10-01-2016, 02:40 AM)Yomet Wrote: In order to complete this request I will now post the code I put together for measuring the Lux value from the Ambient Light Sensor.
Have fun  Smile
Yomet
import smbus
import time
   # For Ch1/Ch0>1.3:
   #    Lux/Ch0=0
   #    Lux = 0
   chScale = 0L
   channel1 = 0L
   channel0 = 0L
   if iGain == 0:
   ratio1 = 0L
   if channel0 != 0:
   b = 0
   m = 0
           b = B1T
           m = M1T
           b = B2T
           m = M2T
           b = B3T
           m = M3T
           b = B4T
           m = M4T
           b = B5T
           m = M5T
           b = B6T
           m = M6T
           b = B7T
           m = M7T
       elif (ratio > K8T):
           b = B8T
           m = M8T
           b = B1C
           m = M1C
           b = B2C
           m = M2C
           b = B3C
           m = M3C
           b = B4C
           m = M4C
           b = B5C
           m = M5C
           b = B6C
           m = M6C
           b = B7C
           m = M7C
       elif (ratio > K8C):
           b = B8C
           m = M8C
   temp = 0L
   if temp < 0:
       temp = 0
   lux = 0L
   return lux
address = 0x49
time.sleep(0.5)
Bravo !!!
  Examples of I2c in Python blanius 8 14,232 10-02-2017, 08:28 PM
  Humidity sensor and temperature under Android dhewko 0 2,755 03-11-2017, 10:18 AM
Last Post: dhewko
  3g/4glte data connection? mightygrom 2 3,719 08-10-2016, 12:17 PM
Last Post: ipsw
