How to open the CSI?
I just wanted to double check before I break anything.
The CSI connector has a white part on the top and a darker part on the bottom. To open it, you need to push the white part up, correct? then slot in the camera and close it again.
Thanks,
NO
You very gently lift the black bar up with your finger nail... no metal tools... and be VERY careful because it is easily broken.
slide the camera cable into the connector with the contact pads down (towards the board) and close the black bar.
(08-30-2016, 04:16 PM)MarkHaysHarris777 Wrote: NO
Thank you!
Glad I asked and thanks for the quick answer
Thank you!
welcome !
Big Grin
