LCD touch pad blank screen
#21
(09-22-2016, 12:53 PM)Ddorrer Wrote:
(09-22-2016, 06:34 AM)Ghost Wrote:
(09-22-2016, 06:16 AM)Ddorrer Wrote: I have the same problem. LCD does not work. Pine64 Support has not responded either, but I submitted a ticket.
What steps have you taken to confirm that the LCD does not work? Please describe giving details of what you did, how you connected the LCD, what operating system image you are using/trying to use, how you burned said operating system, which power supply you are using, and which microSD card. And any other information you can provide that you think might be relevant.
All Kickstarter provided power supply etc.
Update. I got mine working. First. Make sure your are using a clean SD card and try not to overwrite legacy software. Also use the LCD version build. Second. If you have a wireless module that you bought with the Kickstarter kit, REMOVE IT, then boot for the first time. After the device boots initially, turn off and add the wirless module. It should work.
Thanks for posting this, hopefully the information will help others somewhat.
  Reformatting postmarket os with ubuntu touch mackdaddy67 6 8,367 09-11-2020, 12:41 AM
Last Post: SwordfishII
  7" LCD Touch Screen Panel IanJames 0 2,062 04-01-2020, 04:40 PM
Last Post: IanJames
  User Screen Black After Changing Power Settings 0b51Gekko 2 4,736 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  Rock64 + 7" touch screen naviathan 2 5,024 09-28-2017, 09:01 AM
Last Post: naviathan
  7" Screen - Does it work with Debian abasel 1 3,882 07-26-2017, 05:44 AM
Last Post: pfeerick
  RESOLVED - LCD screen not working, HDMI does asuras 10 15,920 04-02-2017, 08:12 AM
Last Post: Luke
  HDMI-VGA adapter. Blank screen. trumad 10 17,864 03-05-2017, 03:17 AM
Last Post: pfeerick
  Does ubuntu img support the touch screen kingsing2 4 7,422 01-29-2017, 02:41 PM
Last Post: greglarious
  Can't get past boot screen... (RESOLVED) codetheweb 13 23,682 01-19-2017, 08:43 AM
Last Post: Michaelrowe01
  How to open Playbox with screen installed? LAPine 3 5,040 12-03-2016, 05:17 PM
Last Post: LAPine
