Android 5.1.1 TV (old-stable, no longer maintained)
trenton4k: the 5.1.1 does not support that
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
(11-12-2016, 10:08 PM)trenton4k Wrote: how do I how do I limit lan to 100 mbit
You can either set the port on your router that the pine is connected to 100 (if it supports that function) or do this: http://forum.pine64.org/showthread.php?t...+speed+100
Both methods worked for me.
Today I went to use my pine and I have no wifi now. I've used it before on this build, just today wifi is "not connected". I tried my Remix card, and WiFi works just fine. Any ideas ayufan?
Matt
Bluphire: WiFi dying after some time? I used for a couple of weeks and did see that.
Releases:
Buy me a Beer
(11-23-2016, 04:52 PM)ayufan Wrote: Bluphire: WiFi dying after some time? I used for a couple of weeks and did see that.
I'm not sure what you mean by "dying". I just know what wifi was working fine on 5.1.1 last time I used it and now this time it does not work. I swapped sd cards with remix and it worked just fine. Put 5.1.1 back in, and still nothing.
Bluphire: do you have adb logs?
Releases:
Buy me a Beer
(11-23-2016, 05:12 PM)ayufan Wrote: Bluphire: do you have adb logs?
Sorry, I don't know what that is...
AYUFAN- can you please look in this? I will provide the adb logs if you will help me understand how to do it.
Thank you.
Hello everyone! I have a problem using the CSI 5M camera. I flashed the android-rooted-ver5.1.1-20160711-pine64-64GB.img, started the Android - it worked fine. Then I turned the pine off, connected the camera module, start the pine back, open "Camera" app and get "Can't connect to camera" message. Attached the camera as suggested on its page. Is it supposed to work? Am I doing something wrong?
[Image: 5mpcamera2_large.jpg]
Sorry, this image (also you mention Pine Inc provided image, which is different from provided by me) is no longer maintained by me.
Releases:
Buy me a Beer
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 388,416 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,673 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,825 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 6,991 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,054 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,614 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,340 07-15-2019, 08:29 PM
  Issues with SD Card and Running Android Twistedx 0 3,549 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,268 02-10-2019, 07:44 PM
Last Post: mmmarcus
  +LTS/SOPINE Android SDK support and Customization biplab777 1 4,681 01-07-2019, 01:21 AM
