For packet loss in 1GbE
Hi, all
Also on the debian image it is to reproduce in Ubuntu image, but if you use the Ethernet in the 1GbE, packet loss will occur as follows.
64 bytes from nrt12s13-in-f196.1e100.net (172.217.25.196): icmp_seq=31 ttl=55 time=4.20 ms
64 bytes from nrt12s13-in-f196.1e100.net (172.217.25.196): icmp_seq=33 ttl=55 time=4.12 ms
64 bytes from nrt12s13-in-f196.1e100.net (172.217.25.196): icmp_seq=34 ttl=55 time=3.90 ms
64 bytes from nrt12s13-in-f196.1e100.net (172.217.25.196): icmp_seq=35 ttl=55 time=4.03 ms
^C
--- www.google.com ping statistics ---
35 packets transmitted, 32 received, 8% packet loss, time 34055ms
rtt min/avg/max/mdev = 3.864/4.070/4.478/0.189 ms
$ uname -a
Linux dns02.kometch.local 3.10.102-2-pine64-longsleep #66 SMP PREEMPT Sat Jul 16 10:53:13 CEST 2016 aarch64 aarch64 aarch64 GNU/Linux
When secured to the 100MbE, but the problem is to eliminate, what this problem is a known problem?
Best regards .
Looks like you're also experienceing this known issue:
http://forum.pine64.org/showthread.php?tid=1844
No short term solution other than switching to 100Mbps it seems
  +LTS/SOPINE Bluetooth: Out-of-order packet arrived bobpaul 1 3,699 05-10-2017, 01:45 AM
Last Post: dkryder
