08-09-2016, 11:46 AM
Is there any way to run owncloud on the pine?
main reason I got it was to make a personal cloud out of it.
OwnCloud on pine64
08-09-2016, 11:48 AM
(This post was last modified: 08-09-2016, 11:49 AM by Leoncito81.)
Owncloud package exists on Arch Aarch64
08-09-2016, 01:01 PM
Yes, for sure! I run it and it works great. It is much faster than the Pi that it replaces. You need to be sure that you install all the pre-requisites, but it is an easy install.
08-09-2016, 01:45 PM
(08-09-2016, 01:01 PM)jl_678 Wrote: Hi, I'm a newbie here, if you could throw together a quick guide that would be amazing!. By the way, I assume you are storing data on a external HDD and not on the SD card, right ?
08-10-2016, 04:35 AM
Mine is using the SD card for storage because I am not storing much. It is not too difficult to store on a hard drive, but you should get that setup prior to installing Owncloud. I have not setup an auto mounting hard drive on Pine, but it should not be difficult. The key is to make sure that it is externally powered. Regarding Owncloud, it is straightforward and there is nothing special required for the Pine. There are many tutorials on the web. Here is an example https://www.howtoforge.com/tutorial/ownc...-8-jessie/ Feel free to ask questions here or on irc if you experience difficulties. Sent from my XT1254 using Tapatalk
08-10-2016, 02:33 PM
Which image should I build it on top off
Debian or Ubuntu ?
08-11-2016, 06:58 AM
Both will work, but I would recommend Debian. It is easier to find HowTo's for Debian in my experience since it relies on more mature packages. The HowTo I provided assumes Debian Jessie which is the version supported on Pine.
Programming languages support under PINE64 | baryluk | 6 | 12,057 |
09-23-2020, 11:46 PM Last Post: Phillip Bell |
Manjaro arm on pine64+ | roel | 2 | 5,778 |
10-19-2019, 05:13 AM Last Post: roel |
Volumio for PINE64 Released | mikelangeloz | 11 | 24,128 |
03-22-2019, 09:25 AM Last Post: llungster |
I2S Audio patches for Pine64+ uploaded to GitHub | ramstadt | 1 | 3,960 |
01-19-2019, 11:31 AM Last Post: ramstadt |
Pine64: Minimal SDL config | Max11 | 3 | 5,852 |
01-04-2019, 03:47 PM Last Post: Max11 |
Fedora 27 on Pine64 | gregjo | 18 | 34,537 |
01-02-2019, 10:42 PM Last Post: heatfanjohn |
Official build procedure of ayufan pine64 | r.tanaka | 0 | 3,065 |
08-21-2018, 10:54 PM Last Post: r.tanaka |
DKMS on kernel 3.10.107-pine64 | obrienmd | 5 | 8,415 |
06-21-2018, 05:45 PM Last Post: evilbunny |
Gentoo for pine64 - longsleep kernel | incoherent | 0 | 3,587 |
12-09-2017, 08:14 AM Last Post: incoherent |
Fedora Running On Pine64! | cztian | 26 | 36,443 |
10-26-2017, 05:51 PM Last Post: gregjo |
