Quick Android Question
I am a Pine64 backer with a primary focus on a Linux home server use case.  However, I am also wondering whether I should get a second Pine64 for an Android use case.  That said, I have a super simple question that occurred to me last night.
Dose Android require a local monitor/screen? In other words, do you have to have a direct connected monitor and mouse to use Android on a Pine?  In Linux, I typically access the system either via remote a CLI through SSH or a remote desktop through VNC.  Does Android have those same concepts and is it easy to setup and run?  Having to have display hardware for a Pine64 Android instance is more than I can manage right now.
Thank you!
Android has an option for screen casting to a capable device (most Smart TVs).
Here you need dedicated mouse and keyboard.
Also, you can install a VNC server on Android. Google for "VNC server" on the play store for examples.
You could take a look at 'airdroid' or other related apps in the play store.
http://www.androidauthority.com/airdroid...pc-269186/
However I do not think they will be as open as remote access to other PC's/linux.
As the Pine64 should have root access (I think anyway), there is a VNC server app I recently looked at.
https://play.google.com/store/apps/detai....vnc&hl=en
I haven't tried them, but they might be worth a try.
(01-25-2016, 07:28 AM)Opine Wrote: You could take a look at 'airdroid' or other related apps in the play store.
1. Pine64 No Root Access Tl Lim is asked some people
http://forum.pine64.org/showthread.php?tid=107
2. next choose is Teamviewer easy to use VNC for  airdroid
http://www.teamviewer.com/
(01-25-2016, 07:56 AM)joe Wrote: 1. Pine64 No Root Access Tl Lim is asked some people
That is good to know its already unlocked/never locked, I have a few apps which require root access.
You have root access on the stock Android build that we released. If there is other Android build comes from other partners, then will depen on their willingness.
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 381,929 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,178 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,534 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 6,872 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 6,940 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,524 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,292 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 253,916 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,495 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 103,820 02-10-2019, 07:44 PM
Last Post: mmmarcus
