System process stopped responding and reboots
So I flashed remix OS 20160718 64Gb on my pine, on a class10 sd card and I'm using the Pine provided power block.
First it took a long time to boot, now the boot is not too bad, after several attempts I managed to get past the keyboard selection and license agreement.
So I'm now on the desktop and I managed to open the settings and to activate the wifi but even without activating it the system process ends up blocking so I choose to wait but no long after the pine reboots....
I was using ubuntu mate for a few weeks without issues except a bit of an unresponsive interface but RemixOs is unusable for me.
Any idea/fix?
(08-08-2016, 05:28 AM)exa Wrote: Hello,
Any idea/fix?
I'm in the same boat just haven't got the time to fIgure out what's changed, I use an apple charger plug but I suspect it's my memory card gone Bad
Sounds like the SD card got corrupted.
Any idea/fix?
it sounds like you have never done much android /remix setup . what you describe is normal for the most part. android/remix in particular takes a while and also reboot one or two times at install. the best thing to do is just leave it alone except for the informations entries.
Any idea/fix?
On the first boot-up of Android it is important to let the system run for at least 15-20 minutes before rebooting or powering off. There are background processes which must complete on the first boot-up and interfering with those just causes problems later.
Just let the system alone for twenty minutes on the first bootup (with the ethernet unplugged) .  Just leave it alone.  Always do a normal shutdown.  With android that means that you must have a power switch installed; either soldered in, or attached with jumpers at the EXP header.   Pressing and HOLDING the power button will bring up the shutdown dialogue...   failing to shutdown and just removing power is a bad idea, leading to corrupt SD cards... words to the wise.
I'm a bit late but I did let it boot up by itself but what happens is that I can't let it run for 15-20mins it just reboots after some time, I guess I can try flashing again :/
Exclamation Adding of WiFi/BT board causing reboots mmb 7 11,149 07-16-2016, 05:06 AM
Last Post: Toriless
