Pine64 Shuts Down
I just installed that build
Ubuntu Linux Image [20160530] based on Longsleep work, build by Pine64
Interesting that with the touchscreen the Pine shuts down just before the login screen appears    Any reasons for that?
Usually the situation you're describing is power related.
... make sure you are using a two wire switching supply rated 5v @ 2.5A 2500ma with wires 18 AWG.
(08-07-2016, 04:21 PM)MarkHaysHarris777 Wrote: Usually the situation you're describing is power related.
That's what  I though   I'm using the power supply that came with it.
Hm... that doesn't sound good.
Mark (or Luke maybe?), have you heard any other issues with the official Pine64 PSU? Both the international and US models are rated at 5v 2A, so *should* be more than adequate. Pine64 with only wifi needs a 700ma (0.7A) capable supply to start, so if you said the display doubled that load to 1.4A, the PSU would seem to be in spec. Would be interested to know if it is 5v, or slightly over-voltage like the better Raspberry Pi ones are (at around 5.25v) to ensure the voltage doesn't sag too much as they are loaded up.
  Disable HDMI Pine64 Andruxa89 1 4,222 01-31-2019, 11:18 AM
Last Post: martinayotte
  Unable to run hello-world docker container on Pine64 kamtschatka 2 5,460 01-24-2019, 04:29 AM
Last Post: arboehm
  KDE on pine64? jamiechang917 6 10,078 01-14-2019, 01:47 PM
Last Post: brigmohan
  External DAC - Pine64 mjgoode 2 5,103 09-05-2018, 12:12 AM
Last Post: mjgoode
  Summer Undergraduate Research using Pine64's pkivolowitz 3 5,117 05-15-2018, 08:17 AM
Last Post: pkivolowitz
  Pine64 2Gb Ubuntu Mono not updating and stuck petec 0 2,912 07-08-2017, 09:34 AM
Last Post: petec
  How to add kernel modules to Ubuntu 16.04 on PINE64+ Taiki Bessho 1 3,872 04-12-2017, 10:01 PM
Last Post: MarkHaysHarris777
  Node.js is not installed properly on Pine64 nsisodiya 1 3,543 12-29-2016, 12:48 AM
Last Post: longsleep
  Finally got Emby server running on Pine64 clarkss12 3 6,291 11-08-2016, 06:04 PM
Last Post: clarkss12
  Firefox on Pine64 S265 2 4,983 09-04-2016, 09:25 PM
Last Post: S265
