Proxy
Hello all,
So im using android and the pine for Xibo signage which is working really well.
Only problem is one element requires internet access, and our network is behind a proxy. now normally if you had wi-Fi you could just enter the proxy however we are using ethernet.
Is there a way to set the http proxy for ethernet?
Thanks,
Read through this, and see if it helps...
  How to Setting Proxy Server in Android x-86 Kitkat, Lollipop and Marshmallow deniyulianti 1 3,974 01-15-2017, 01:35 PM
Last Post: Ferio
