recommended micro sd card ?
I ended up getting a 64GB Samsung EVO+ for my pine, due in part to this article.
http://thewirecutter.com/reviews/best-microsd-card/
Mostly, because I plan to use my pine as a tablet, I was interested in the higher random read/write speeds. The article was worth the read imo.
Performance of cards varies widely for random io, but most advertising is for sequential speed.
Samsung EVO is what I have in my Raspberry Pi after lots of research.
(03-02-2016, 06:39 PM)benpope81 Wrote: Performance of cards varies widely for random io, but most advertising is for sequential speed.
I have several Samsung EVO and EVO+ with different memory configuration (16G to 128G) in my lab and all works well.
Here are some of my tests on the Pi and Pi2:
https://www.raspberrypi.org/forums/viewt...48#p691848
You can trawl the entire thread, but I don't think you'll find a card that beats the EVO.
Not all class 10 SD cards are equivalent.  SD cards are optimized for sequential read/write from cameras.
Here's the best resource I've found benchmarking micro sd cards for SBC use:
http://www.jeffgeerling.com/blogs/jeff-g...crosd-card
So, another vote for Samsung EVO.  They work really well in my RaspberryPis and they're not even that expensive.
Just saw FRY's advertising that they have the 32GB Samsung PRO+ @ $9.99, in store only, limited to 5 per customer, good thru Mar 19.
(03-17-2016, 09:19 AM)SkimMilk Wrote: Just saw FRY's advertising that they have the 32GB Samsung PRO+ @ $9.99, in store only, limited to 5 per customer, good thru Mar 19.
I just purchased 5 pieces an hour ago and needs promo code to get this price. Here is my additional promo code: 3711579 but only can use one time.
I'm not in the states so won't be able to pick this up. Will be grateful if anyone can help me grab 2 or 3 of these and mail them over to me? Big Grin
#19
Hi, I wonder if it will be ok to use a 8GB or do you recommend 16GB instead?
#20
(03-18-2016, 05:59 AM)Zoltrix Wrote: Hi, I wonder if it will be ok to use a 8GB or do you recommend 16GB instead?
It will be ok to use an 8GB card, you will just have less space if you wanted to download or store anything (apps, games, movies, etc).
Cards up to 128GB have so far been verified as working.
  Recommended kits to buy? Silk 1 3,309 12-06-2020, 11:28 PM
  How to boot from SD card on pinebook pro linux123 3 6,089 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 4,477 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 4,382 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 6,471 03-18-2020, 09:42 AM
  eMMC card on adapter Malmgren 8 11,253 03-20-2018, 11:14 AM
Last Post: Malmgren
  corrupt microsd card after reboot maxpayne 6 10,114 02-08-2017, 05:42 PM
Last Post: maxpayne
  unable to write an pine64 image on a 16G micro suresh 2 5,401 01-26-2017, 12:56 PM
Last Post: suresh
  recommended micro sd card? Gustavo Woltmann 1 3,624 01-03-2017, 11:38 PM
Last Post: MarkHaysHarris777
  What is on the Micro SC card that came with the board? clawinus 1 3,691 11-03-2016, 02:33 PM
Users browsing this thread: 8 Guest(s)
