Solid Model/Accurate Blueprint
(04-13-2016, 09:45 AM)Tarjei85 Wrote: It would be nice to have the power an reset buttons as well. Other than that. Thanks for the work Wink
Hah - I haven't soldered the one I got on yet - are those switches both the same momentary contact or are they different components?  If someone has measurements now I could add them to the cad model, otherwise I'll have to measure later after I put it on.
wm
About this model it should be. Here is a step-file
https://drive.google.com/open?id=0BwdGZc...WJRRkRzWW8
(01-24-2016, 02:49 PM)Atomkinder Wrote: Saw some mention of dimensions in the 'Cases and Enclosure Question' thread, but I'm hoping for a nominal dimension solid model if possible, or at least a good print to work from. I'm a machinist by trade and want to try a few enclosure designs and the one REV B drawing is only for outer board dimensions which isn't going to do it. I want to be able to design and machine aluminum cases with integrated standoffs and the like.
Will a non-STL* model be available sometime soon? I would like to start designing before the board arrives in March.
*(hopefully something like a STEP or IGES solid model, or dare I say SolidWorks)
 try this:
https://grabcad.com/library/pine64-a64-db-2gb-rev-b-1
(04-13-2016, 09:29 AM)w1ntermute0 Wrote: If it helps anyone I threw together a rough CAD model, it's located here (see photo in attachment):
http://www.3dcontentcentral.com/parts/do...alogid=171
This is all based on measurements I took off my board, so don't get mad if you use it and your holes don't line up or whatever, but I tried to be as accurate as possible.  Let me know if you see any corrections needed.
Enjoy.
wm
this is also available thanks
Question Complete blueprint of the Pine Tarjei85 11 31,481 06-11-2016, 09:06 AM
