Android USB debugging and OTG device mode
From what I can tell Android USB debugging is not working because the OTG port can't be forced into device mode.  It boots in host mode and stays that way.
So is there some command that will force it into device mode? Even better would be to hook up "enable USB debugging" to force the port into device mode.
How this is normally accomplished is via a pin in the OTG cable. But we only have a normal USB jack so the OTG detection pin is not available. So... we need some kind of software command to force USB device mode onto the jack.
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 388,143 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,642 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,804 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  New Device Trees for A64 jonsmirl 4 8,378 02-18-2020, 07:03 AM
Last Post: j23
  Android Things OS dqvsra 2 6,983 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,048 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,610 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,339 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 257,767 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,547 02-26-2019, 11:58 AM
Last Post: Twistedx
