Batch Schedulers on pine64
I support a Torque cluster at work and was looking to create a sandbox to test some ideas of my own.
It looks like Torque on Ubuntu could be a winner, following these instructions:
https://jabriffa.wordpress.com/2015/02/1...14-04-lts/
update: the head node set up procedure worked perfectly on ubuntu xenial but needed to use real IP in /etc/hosts rather than 127.0.1.1
https://jabriffa.wordpress.com/2015/03/2...14-04-lts/
I also took a stab at Son of Grid Engine on Ubuntu and the gridengine-* packages on Debian.
For Son of Grid Engine, sge-common installed, but I could only find amd64 package for the binaries.
For gridengine-* on Debian, I ran into a similar problem that only armhf binaries were available, so I tried this:
dpkg --add-architecture armhf
but the binaries still would not install due to unresolvable dependency errors.
Backer #17,640
  I started blogging on Pine64 Cluster salmangano 13 18,301 04-12-2017, 12:44 PM
Last Post: Shad0wSt4R
  Pine64 Cluster economy baryluk 5 11,005 06-19-2016, 09:13 AM
Last Post: JasperBrown
