Partial boot after installing Manjaro on emmc
Thumbs Up
Hi, the problem is solved.
I installed Tow Boot on the emmc which solved the problem.
However, when Tow Boot is installed on the SPI, I have exactly the same problem as with U-Boot: the system does not detect the encrypted partition on the SD card, it does not detect the SD card at all (no /dev/mmcblk1), booting is impossible and I get into an emergency shell.
Procedure:
On another computer, download the latest version of Tow Boot at https://github.com/Tow-Boot/Tow-Boot/releases. Choose the pinebookPro version.
Assume the latest version is pine64-pinebookPro-2021.10-005.tar.xz
$ wget https://github.com/Tow-Boot/Tow-Boot/releases/download/release-2021.10-005/pine64-pinebookPro-2021.10-005.tar.xz # download archive
$ tar xvf pine64-pinebookPro-2021.10-005.tar.xz # unzip
$ cd pine64-pinebookPro-2021.10-005
$ cp shared.disk-image.img [your-usb-stick-location]
$ sudo -s
# dd if=spi.installer.img of=[your-SDcard-location-in-/dev/] bs=1M status=progress
Then, I plugged the USB key into the faulty computer, and I started it with the encrypted SDcard to arrive at the emergency shell.
Perhaps due to the abnormal boot, I was unable to use dd with the options given in the documentation.
On the emergency shell,
# dd if=shared.disk-image.img of=/dev/mmcblk2 bs=1M oflag=direct,sync status=progress # /dev/mmcblk2 is internal emmc memory.
returns an error.
So I used the command:
# dd if=shared.disk-image.img of=/dev/mmcblk2 bs=1M oflag=direct conv=fsync
Source.
What worked.
Then I replaced the encrypted SDcard with the Tow Boot SDcard containing spi.installer.img, rebooted and overwritten the SPI memory.
Finally, I replaced the Tow Boot SDcard with the encrypted SDcard, and when I restarted, everything was working normally.
I tried to install Tow Boot on SPI memory, but as I said, Tow Boot on SPI does not detect the encrypted SDcard.
I haven't tested unencrypted system boot on emmc with Tow Boot on SPI. As Tow Boot works on the emmc, I leave it as is.
Thanks for your help, wdt and KC9UDX!
Pinebook Pro, standard config (Manjaro)
FYI (and anyone else) the problem with the command,,,
dd does not work with csv (comma separated values) only <parmeter>=<value>
gotta wonder how (emmc) mbr persisted
  Manjaro versions bad and good gilwood 0 243 02-12-2024, 05:03 PM
Last Post: gilwood
  uboot wont boot to SD card after upgrade jbradley419 7 802 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 286 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,210 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 686 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 584 11-22-2023, 11:47 AM
Last Post: fxc
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 60,083 11-20-2023, 06:22 PM
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,171 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,863 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 795 07-13-2023, 01:50 PM
Last Post: PaulQ
