Most recent Mobian image or installer image known to work?
(02-07-2023, 08:35 AM)Gumur Wrote: And the 20230205 is also OK.
It's ok as long as you don't upgrade. In my case, I'm stuck with a black screen.
Sorry, I did an upgrade today,and works as expected.
Have you rebooted at least once? For sure, yesterday, I wasn't alone to have to disable greetd and to reenable phosh to make it work.
I used installer...20230212 and it does decryption ok, but from then on stuck with a grey screen.
If I use tow boot to mount to laptop I get `part /media/user/boot` and `/media/user/root` mounts, the root I have to supply crypt password.
If one looks at the emmc with cfdisk there are 3 parts to it:
Device Boot Start End Sectors Size Id Type
>> Free space 2048 16383 14336 7M
/dev/sdb1 * 16384 999423 983040 480M 83 Linux
/dev/sdb2 999424 61071359 60071936 28.6G 83 Linux
It appears the root partiion is not expanded but encrypted part is 31G, i.e expanded
The free space, if highlighted reports a UUID, of type ext4, label of boot and mounted at /media/user/boot
Is this a quirk of cfdisk or is the table of eMMC corrupted in that it is remembering boot partition of previous install [ it crashed after an upgrade late last year ].
I'm downloading the install....20230226 tonight to see if that is the same.
  Mobian repository status henrythemouse 16 8,600 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,869 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 120 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,912 11-22-2023, 11:46 AM
Last Post: aLoop100o
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 2,090 09-05-2023, 11:16 AM
Last Post: nickolas
  What actions needed to keep on mobian testing user641 3 1,779 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 622 09-01-2023, 11:29 AM
Last Post: Mahgue
  Chatty does not work after suspend mode user641 4 1,887 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  how to update mobian over tor vusra 13 6,826 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,882 07-09-2023, 01:37 AM
Last Post: vusra
