Debian fp-compiler the how to guide
Well thanks to debian stretch having made arm64 packages
Here are the needed packages copy them to the pine64 and install with dpkg -i
I ran into trouble installing kodi but i was not going to let a few minor issues stop me...
alternatively you can just use the debian stretch sources but be warned its not stable....
.zip   Making debian like kodi.zip (Size: 863.69 KB / Downloads: 238)
My debian images come packed with Kodi as they are included in the backports repositories (jarvis).
The UI is slow due to lack of 3d acceleration at this point (gl) but you can set it to use software rendering and playback streams in windowed mode.
Once we have the Mali drivers working (right now the drm stack is what's holding things back.) this address should be worked out in no time Wink
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
(07-17-2016, 10:50 AM)lenny.raposo-pine64.pro Wrote: My debian images come packed with Kodi as they are included in the backports repositories (jarvis).
Fair enough I've just had the issue of it complaining about missing dependencies but it could just be that I somehow broke the install
  Debian installer on Pine A64+ but no hdmi mrwick 1 4,885 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 12,749 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 2,942 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 10,092 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 121,111 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 4,756 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 4,190 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 6,263 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 13,065 03-29-2019, 02:00 AM
Last Post: desai_amogh
  (ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release lenny.raposo-pine64.pro 259 459,980 05-21-2018, 06:30 AM
Last Post: Luke
