USB Wall Plug and Power over Ethernet not working
just as with the raspberry pi , it depends on what you plan to do with the pine64 board (or boards) when determining what power supply to use. if you plan to use the board as a single unit then many 2.5amp power supplies will probably supply enough current. if you plan on adding the POT expansion with several modules/sensors, and/or the development expansion board with additional power requirements then 2.5amp most likely will not perform well. so my suggestion is to think about what you want to do and buy accordingly. also, keep in mind that adapter plugs/cables that will change from usb to pole barrel plug and even Y-cable to allow multiple boards off one power supply are available.
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 3,009 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 25,242 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 3,479 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 9,187 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 15,421 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 6,246 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 28,888 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 6,828 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 18,090 01-07-2017, 11:59 PM
Last Post: aegrotatio
  First cable for Euler Bus power done! AVL2016 24 32,568 10-05-2016, 06:43 AM
Last Post: Ghost
