720p video in Firefox
I am using postmarketOS Phosh on the PinePhone.
Firefox is incapable of playing 720p video, even with the Firefox ESR hardware accelerration settings enabled.
Sometimes it completely lags for seconds, sometimes only a little bit, when UI (video controls/Phosh UI) is shown.
Needless to say, it gets very hot.
VLC can not even play a video.
What do you recommend for playing 720p video properly?
I don't know if hardware acceleration is REALLY used (even if enabled in FF), perhaps there is still some GPU driver support missing for it...? Huh
Anyway, I don't think it is possible at the moment to view 720p videos in a browser on the original PinePhone without performance problems.
I think the hardware is just too slow for this?
I'm using Mobian and only view videos in 360p or 480p, 720p just won't work.
(But I'm ok with that for now, on such a small display I don't really need 720p that bad...)
But IF hardware accelartion is still NOT used in general at the moment, situation could change of course.
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
(11-22-2022, 05:01 AM)dante404 Wrote: I don't know if hardware acceleration is REALLY used (even if enabled in FF)
No, it isn't. You can check it in about:support -> Graphics -> Compositing: it says "WebRender (Software)". With hardware acceleration in use it would say "WebRender".
PinePhone Beta Edition 3GB RAM - custom firmware v.0.7.4 - ADSP v.30.007 - postmarketOS edge - sxmo
(11-22-2022, 05:01 AM)dante404 Wrote: I don't know if hardware acceleration is REALLY used (even if enabled in FF), perhaps there is still some GPU driver support missing for it...? Huh
Do you use some media player that can play 720p? Media player performance is usually better than Firefox video player.
Anyways, it should be noted by Pine64 on the product page. I think most users except at least 1080p from a recent phone.
(11-23-2022, 07:56 AM)notramo Wrote: Do you use some media player that can play 720p? Media player performance is usually better than Firefox video player.
Yes, I use also VLC. 720p in VLC works better than in Firefox, but still not 100% lag free on my PInePhone (non-Pro).
@alpineduck : OK, thank you!
Photo Can no longer take pictures, /dev/video* not recognized as video devices 64_Tesseract 0 577 01-26-2023, 10:19 AM
Last Post: 64_Tesseract
Video Questions about filming video with the Pinephone MirceaKitsune 10 9,687 06-02-2021, 01:47 PM
Last Post: vortex
  Touchscreen broken on arrival [*now with video*] ozzeruk 10 12,204 08-06-2020, 09:59 AM
Last Post: HLing
  Hardware accelerated video encoding PinePhoneCoder 4 5,642 02-20-2020, 02:13 PM
Last Post: PinePhoneCoder
