Gnome settings crashes in Mobian after magnification change.
I restarted my installation of Mobian on the SD card in the PinePhone Pro. It works well after a dist-upgrade on October 28, 2022.
But I changed the screen magnification in gnome settings, which resulted in gnome settings crashing on its startup. The solution is to delete the binary format file, ~/.config/dconf/user .
Thank you for your post, mburns. This bug was driving me crazy!
After daily updates as of November 24, my copy of Mobian is disabled. the console, Settings, and other applications crash.
OK now! Mobian is back in working order after an update as of 8:36am EST. But clicking on some options in Settings will crash it.
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 9 1,672 02-20-2024, 12:40 PM
Last Post: mburns
  Disable the GDM service in Mobian. mburns 0 455 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 869 11-18-2023, 08:21 AM
Last Post: crocspot
  Fix the Mobian Weather App mburns 0 488 11-07-2023, 10:01 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 688 11-07-2023, 09:44 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 588 10-14-2023, 11:57 AM
Last Post: mburns
  Stupid UI Question (PPP/Gnome?) dwellerbelow 3 782 10-12-2023, 07:07 PM
Last Post: dwellerbelow
  Mobian libnotify custom notifications MadameMalady 5 1,379 08-01-2023, 08:51 AM
Last Post: MadameMalady
  Mobian .desktop file creation MadameMalady 15 3,092 07-27-2023, 04:12 PM
  XFCE mobian running nicely but some oddities grump_fiddle_reinstall 0 797 07-01-2023, 08:18 AM
