WiFi stopped on Pinebook Pro after update
After being gone for a month, I returned yesterday 23 Oct 2022 and thought 'let's update the Pinebook pro while I unpack'.  Running Manjaroo.  So I did, and after restart, WiFi no longer works.  Networks show "No available connections".  WiFi is on through the privacy switch (2 led blinks).  Any ideas how to fix?
Maybe this
https://forum.manjaro.org/t/wi-fi-stoppe...e/124956/2
(10-24-2022, 09:58 AM)tkudog Wrote: After being gone for a month, I returned yesterday 23 Oct 2022 and thought 'let's update the Pinebook pro while I unpack'.  Running Manjaroo.  So I did, and after restart, WiFi no longer works.  Networks show "No available connections".  WiFi is on through the privacy switch (2 led blinks).  Any ideas how to fix?
@tkudog I had the exact same thing happen.  Then I contacted support and was given limited info.
I was going to trash my pinebook (the trackpad is crummy and I don't want to spend more on it with a replacement part, etc.)
SO, I created a new account "foo" in order to delete my old account.  But the WiFI works in new account "foo".
Give it a try.
What is my guess?  The update messed up the WiFi settings on that one account, and I have no idea how to fix the settings.  (I am pretty technical and looked at all the settings - saw nothing amiss.)
Give it a try.
Sorry, the link in the first reply solved my problem:  "Try a cold boot.  Wifi and Bluetooth is really flaky when doing reboots/warmboots."
  Debian on Pinebook Pro u974615 7 840 03-31-2024, 10:11 AM
Last Post: u974615
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 304 03-01-2024, 06:46 PM
Last Post: Puckla
  Pinebook Pro upgrading from the factory image yamsoup 12 1,455 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,080 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,161 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 88,032 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,177 11-23-2023, 07:37 AM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 860 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,160 08-31-2023, 04:20 PM
Last Post: TRS-80
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 1,998 08-21-2023, 09:10 PM
Last Post: vanessadonald
