Audio Stuttering Issue
I have been daily driving the PPP for just over a month and most of the issues I initially found have been resolved. However, the audio output when I play music seems to be a persistent issue. (I am running Manjaro-ARM with KDE Plasma Version 5.25.5) The EMMC was flashed with this, so its likely not a factory software issue.
The music is from an SD card and when played on other devices (including the PPP with certain restrictions -see below) works just fine.
Following this thread's advice, https://forum.pine64.org/showthread.php?...ephone+pro  , I chose to change the config file in /etc/pulse/daemon.conf  to have
realtime-priority = 9
This made no difference (at least that I noticed)
Another thread,  https://github.com/manjaro-pinephone/pho.../issues/18  ,suggested lowering the volume to 50%. This completely removed the stuttering issue, and I have been able to get away with practically no stuttering at 65%.
In short, I'm wondering if anyone has found a permanent solutions to this issue or if this could just be a power management issue from the hardware.
Thanks!
  Pine Phone Pro audio on phone calls: discussion, support and tips apink 42 12,406 12-26-2023, 02:14 PM
Last Post: apink
  Any tips to improve the audio quality of calls on the PinePhone Pro? tux_life 2 1,522 05-12-2023, 12:58 PM
Last Post: alaraajavamma
  PinePhone Pro Manjaro Plasma Mobile Beta 13 & No Audio with Phone Calls X0X0X0X0X0 0 1,097 11-02-2022, 02:09 PM
Last Post: X0X0X0X0X0
  Outgoing audio in phone calls gone linuxfreedom 6 3,324 10-25-2022, 08:40 PM
Last Post: apink
  Suspend audio issue kmsgli 4 2,943 08-03-2022, 04:11 PM
Last Post: Subsentient
  Audio sinks disappeared Modsognir 1 1,104 08-03-2022, 01:57 PM
Last Post: Modsognir
  Manjaro Plasma Beta 11 sleep issue after 3/22 update Fred Zyphal 6 3,923 05-22-2022, 12:37 PM
Last Post: magdesign
  Screen keyboard Japanese input issue Yst 1 1,196 04-30-2022, 09:13 PM
Last Post: TRS-80
