No boot after Manjaro flash
@bburdette
mtd (memory technology device),,, it is not so clear,
Did you write or install something OR just try to boot?
If just boot, try hard reset (hold pwr button 20+ sec)
and obviously SD card out
(09-27-2022, 08:52 AM)wdt Wrote: @bburdette
Ah yes, mtd.  No I wanted to try writing to that with nandwrite but the device wasn't visible in the old version of manjaro.  So I attempted booting from new manjaro on SD, and that apparently bricked the pinebook.  So I never got to try writing to mtd0.
I won't be able to try the 20 seconds trick till Friday, but thx.
Holding the power button down for 20 seconds doesn't do anything.  No leds, no nothing.
Try removing the EMMC card and putting it on the USB adapter and boot from that using tow boot. That was the only way I could boot Manjaro-ARM-kde-plasma-generic-22.08.img. Obviously not a solution but debug step.
I can't figure out if tow boot or Manjaro is the issue though as the issue only happened after the Manjaro update but tow-boot shows GPT partition errors that I think mean it can't find the GPT partition. When I put the EMMC card on the USB adapter and boot from that it can find the partition just fine and boot.
@bburdette
After the hard reset, you have to try and start it the normal way, ~1s press
Just if you didn't understand
gdisk has a v = verify command
in the recovery menu = r you could try g = convert to MBR only OR f = rebuild GPT from MBR
(only if MBR and GPT match partition count numbers, o MBR and p GPT in recovery menu)
or there may be other problems that verify will tell you about, maybe the backup is not at end of disk
  Manjaro versions bad and good gilwood 0 234 02-12-2024, 05:03 PM
Last Post: gilwood
  uboot wont boot to SD card after upgrade jbradley419 7 761 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 277 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,175 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 659 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 569 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,147 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,832 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 788 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,911 06-14-2023, 07:20 AM
