Slow Teathering With PinePhone
(10-07-2022, 02:00 PM)treebeard Wrote: There are various posts suggesting some nftables magic can change the TTL to evade the sniffing but I haven't been able to get that to work.
For what it's worth, I did find a way to "fix" the TTL but it was not enough to avoid Verizon's tether-block.  After starting tether (or hotspot) do
sudo nft add rule ip nm-shared-usb0 filter_forward index 0 ip saddr 10.42.0.0/24 iifname "usb0" ip ttl set 64 accept
This will make the filter_forward chain look like:
chain filter_forward {
    type filter hook forward priority filter; policy accept;
    ip daddr 10.42.0.0/24 oifname "usb0" ct state { established, related } accept
    ip saddr 10.42.0.0/24 iifname "usb0" accept
    iifname "usb0" oifname "usb0" accept
    iifname "usb0" reject
    oifname "usb0" reject
... where rule #3 becomes redundant but harmless.  This is quite a bit different than the other techniques I ran across, and perhaps it's not the best approach.  I leave it here in case someone else finds it useful.
  PinePhone - boot from microSD laserpyramid 6 550 04-22-2024, 02:22 AM
Last Post: bongosunny
  pinephone virtual keyboard aular 4 345 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 230 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 108,929 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,783 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 602 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,340 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 493 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,680 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,943 12-04-2023, 02:14 AM
Last Post: Peter Gamma
