Problem with booting from SD card. Several errors
Question
I’m trying my luck here in getting help with the issues on my PP og:
I was updating manjaro phosh from v25 to 26, when autosuspend kicked in and the screen didn’t come back. I turned the phone off to early and now I get the following error and the os doesn’t boot:
Quote:[0555641] lima ic40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
[2730020] pinephone-keyboard 2-0015: error: ENXIO: Failes to read device ID
[9.198729] i2c i2c-1: mv64xxx_i2c_fsm: Ctlr Error — state: 0x2, status: 0x0 addr: 0x48, flags: 0x0
[9.200060] stk3310 1-0048: registrer read failed: -11
[9.902770] iio iio: device4: failed to read Who-Am-I register.
[9.936683] debugfs: File ‘Bluetooth Playback’ in directory ‘dapm’ already present!
[9.956676] debugfs: File ‘Bluetooth Capture’ in directory ‘dapm’ already present!
I'm running the OS from the SD-Card. I tried to flash other SDCards with Manjaro and other OSes and either I get similar errors and the OS does not boot or if it does boot after a long time, there are other issues. The OS from the eMMC runs without a Problem, as far a as I can tell. So I think there is something messed up with booting from SD in general.
Thanks for your help!
  How do I import SIM card contacts? Logological 8 5,203 06-04-2023, 12:49 PM
Last Post: mruser1
  SMS Problem hugh_barnard 2 1,251 05-10-2023, 04:24 AM
Last Post: acrux
Bug Problem with cameras/Megapixels? danimations 23 9,222 04-27-2023, 05:00 AM
Last Post: Eugo
  Can't add micro SD card to Pinephone thorensjubilee 7 2,459 02-27-2023, 10:21 AM
Last Post: mikehenson
  Screen blocker is damaged ("loginctl unlock-session c1" problem) Gon 2 1,902 09-29-2022, 12:42 PM
Last Post: Firewave
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 8 7,199 04-30-2021, 03:42 PM
Last Post: Timothy_Ecc
  Manjaro Plasmamobile not booting after update [Solved?] quixote 9 7,694 04-08-2021, 12:45 AM
Last Post: quixote
  Manually mount SD card in running system? lsitongia 3 3,708 03-03-2021, 11:27 AM
Last Post: lsitongia
  Latest dev build of plasma manjaro not booting paju1986 10 7,998 02-26-2021, 10:44 PM
Sad Cannot play songs directly from SD card SameExpert 2 3,019 01-25-2021, 04:33 AM
Last Post: SameExpert
